EVO IV noises
Old Aug 23, 2009 | 07:01 PM
fragmonkee's Avatar
EVO IV noises
Hey guys, recently posted my Evo IV I just picked up this weekend. The car is overall really clean, especially the under carriage. My question is when im turning I hear a tire rubbing noise coming from the rear (dont think they are actually rubbing due to the fact that they are stock wheels and stock ride height.) My tires may be too wide (205/50/R16) but im not sure...could this be the rear dif? I believe the IV was the first year for the AYC but not certain...anyone else had this?
thanks!
Chris
-Me and the wife's Twin Turbo Legacy
Old Aug 23, 2009 | 07:26 PM
1d10t's Avatar
Not a ton of experience with AYC in the states, but I could imagine a noise from a differential being made while the two wheels traveling at different speeds (such as when you're turning) if there were an issue with clutches internaly maybe. You'll need to take it to the shop for someone with experience to diagnose the problem successfully.
Good luck, keep us updated
Old Aug 23, 2009 | 08:05 PM
R0b's Avatar
R0b
a few questions
1. Knocking type noise or a constant scraping/rubbing noise?
2. noise only occurs under full turn (like when youre u turning) or even when you turn around slight corners as well?
3. whats the level of atf fluid like in the reservoir - its in the boot in evo vii's but not too sure about the iv
Old Aug 23, 2009 | 08:47 PM
fragmonkee's Avatar
Originally Posted by R0b
a few questions
There is a fluid reservoir in the trunk, wasn't sure what it was (didn't really have a lot of time to play with it Saturday). Ill give that a go. It only does it when making 90 degree turns...it really sounds like tires rubbing the wheel well. What exactly is in that reservoir? is that for the diff?
Old Aug 23, 2009 | 11:08 PM
Yogi_B's Avatar
The AYC diff will make funny noises under cornerning when its in need of a service so best take it into somewhere that knows evo and give the thing a good flush and bleed.
Old Aug 24, 2009 | 05:58 AM
4G63Rules's Avatar
It almost sounds like you have a welded center diff.
Old Aug 24, 2009 | 07:08 AM
94AWDcoupe's Avatar
Most likely failing rear AYC clutches. If its making noise its too late for flush in hopes of cure.
Old Aug 24, 2009 | 12:53 PM
evo_gerard's Avatar
if your ayc IS making noise then it may need an oil change and bleed (granted that thats where the noise is comin from). try to get an evo IV workshop manual, it will give u the proceedure before any of t the MUTII stuff that our newer manuals have. i got one over the net u just have to do some searching
Old Aug 24, 2009 | 02:08 PM
my3awds's Avatar
I know where you can get the evo4 workshop manuals online if you need it. You might want to jack up the car so all 4s are in the air. Try turning one of the rear wheels by hand and see what happens to the other side.
Old Aug 24, 2009 | 02:15 PM
R0b's Avatar
R0b
sounds like it just needs a flush and fluid change.
try that first.
if it doesnt help, hope you have deep pockets.
Old Aug 24, 2009 | 04:09 PM
fragmonkee's Avatar
ok checked the rear reservoir and it is barely on the stick. I'm guessing that this is the problem...(hopefully). Any information on how to flush this thing and bleed it would be very helpful...I have access to a full shop so I have everything that I would need.
thanks guys!
-Chris
Old Aug 26, 2009 | 03:47 AM
resart's Avatar
I had a knocking in the front left from new. It took them 2 years and many visits later for them to fint it was a lower ball joint lol
Old Aug 26, 2009 | 09:08 AM
4Trouble's Avatar
You may also want a little more check on the car. I don't think the IV ever came in that color and the indicators were brown-like orange. Little off topic but just FYI...
Old Aug 26, 2009 | 09:16 AM
4Trouble's Avatar
And yes, IV was the first to have AYC (VIII MR or 8.5 is the first to have S-AYC) but only on GSR models, unless you custom fit on to RS. Usually the obvious cues are black door handles, black mirror and cheaper interior but it seems your car has custom paint and changed interior. RS are really really rare in Japan though so your car is likely to be a GSR and has AYC.
Old Aug 30, 2009 | 06:34 AM
fragmonkee's Avatar
It is a GSR, the color used to be white, but i guess the dude that had it liked canary yellow...
