Door for gas tank broken??
Old Jan 13, 2011 | 11:17 PM
  #31
D-Mon3y69's Avatar
Ya no problem. Glad you got it fixed.
Old Sep 28, 2011 | 12:17 AM
  #32
Armsolut's Avatar
thx a lot for the help!!! all this help really made my day!!!!
Old Sep 28, 2011 | 12:31 AM
  #33
Bizlibati's Avatar
Any time this kind of took place if you ask me, My partner and i set several plastic close to the particular show so that it keeps on there eternally.. took place if you ask me 2 times just before, yet by no means once more since i would in which.
Old Jul 27, 2014 | 02:50 PM
  #34
alberitoo's Avatar
I just pop the trunk open and pull the cable to pop it open
Old Jul 27, 2014 | 03:57 PM
  #35
DSMorBUST's Avatar
this happened to me this week on Monday.... I had to had someone hold the fuel lever inside "up" while I used my card to pop open the door.... REALLY annoying.... finally had time to go to the mitsu dealer and pick up a replacement clip... it was $2.02.... so I grabbed two...
Old Nov 13, 2019 | 01:54 AM
  #36
food andfingers's Avatar
It's 2019 fellas and this happened with me. Stayed in line for 20 min reached up to the gas pump and boom !! Fuel door doesn't open !! But i know what to do, Thanks to you guys !
Old Nov 13, 2019 | 02:06 PM
  #37
barneyb's Avatar
When mine broke last week I fixed it with a coil spring I had in my junk drawer.
Old Nov 20, 2019 | 06:38 PM
  #38
jxp427's Avatar
Veteran: Air Force
It's definitely the gas door spring, I had to have a bystander hold the gas door lever while i used my drivers license to pry door open ( wasn't hard to pry) and then the spring fell into pieces on the ground. I bought mine off amazon for $7 dollars. beler MR970563 is the item and you should be good to go in no time!
Old Nov 20, 2019 | 09:38 PM
  #39
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
I used to cram my keyfob into the gas door lever until I fixed it.. works in a pinch.
Old Dec 6, 2019 | 08:01 PM
  #40
krys88's Avatar
gas door spring
Old Dec 8, 2019 | 10:49 PM
  #41
barneyb's Avatar
I wrote above about how I had fixed by gas door with a junk drawer spring. Well, Thanksgiving morning, about 2:00 A.M., driving on closed interstate in sustained 60 mph winds, blowing and falling snow, I stopped for gas, can barely stand in the wind, and the gas door won't open. Got a new spring from Amazon.
EVO8STI
Jul 22, 2017 04:29 PM
akqowns
Jun 7, 2017 09:38 PM
Kian
Mar 29, 2013 08:53 PM
phishy
Apr 1, 2010 01:19 PM
dyulov
Apr 22, 2009 04:08 AM
