Phantom Knock in Low RPM
Old Aug 31, 2009 | 01:56 PM
t-revzr's Avatar
Originally Posted by sdfontanini
Thanks for the advice T-revzr I'll check that out. Exactly my point on the power loss though. All the pulled timing makes it run like crap.
Not a problem let me know what you find out! I will prob be changing my clutch in a month if you end up doing it before me and that fixes it i would like to know! Good luck!!!
Old Aug 31, 2009 | 02:03 PM
sdfontanini's Avatar
What clutch do you have in there t-revzr?
Old Aug 31, 2009 | 02:11 PM
whitey4d's Avatar
If you know its phantom knock why not mod the knock tables?? Very common with big turbo multi plate clutches and some others mods.
Old Aug 31, 2009 | 02:21 PM
I will do one last detonation test with my det cans tonight with my tuner and then I'll probably adjust the knock sensor table in that region.
Old Aug 31, 2009 | 02:35 PM
t-revzr's Avatar
Im on the stock clutch still lol
Old Sep 8, 2009 | 12:52 PM
I am beginning to hate my Evo.
Car records 15-36 counts of knock just about everytime I pass 3000 rpms.
Det cans prove to me it's false knock.
What the hell should I do?
Old Sep 8, 2009 | 04:42 PM
PaperClip's Avatar
If you can check the sensor near the drivers side front of the motor. Maybe with the bigger turbo it got too hot and maybe messed somethin up? Maybe a knock sensor is going bad? if you have anyone in the area that you know you can try swapping sensors to see if thats whats causing the fals signal. I dunno though Im in class right now so I am just taking some guesses. Good luck man.
Old Sep 9, 2009 | 02:46 PM
darkside4G63's Avatar
is this related to the p0300 multi misfire that a lot of evo8 guys get along with the part throttle hesitation @ 3-3.5k in 5th gear? i'm having this issue and i was going to adjust the knock filter in Ecuflash in some of the lower load cells @ 3k rpms. thing is im not sure which why to adjust the value (up or down) to make the knock sensor less sensitive. sorry for the thread jack but any help would be great.
Old Sep 9, 2009 | 08:09 PM
MEVOLV3's Avatar
P0300 reared its ugly head at least twice a week until I swapped new DP hangers, almost a month no lighted dash, knock on wood...no pun intented
Live4Redline
Jul 17, 2024 07:09 AM
4b11slayer
Nov 1, 2016 02:38 PM
Mauricio Evo IV
Sep 21, 2016 02:45 PM
MrJuls
May 9, 2013 10:04 AM
Seijuro
Mar 17, 2010 06:13 PM
