Need help with Oil cap
Old Sep 2, 2009 | 08:40 PM
jahnplay's Avatar
i don't know what the problem is i took it to the dealer i bought the car from they changed the spark plugs, and wires which caused the service engine light to come up and it was PO300, they fixed it and they said they changed the oil cover that was leaking oil and they went in the plugs.
now the car is doing the samething when i go for a ride theres oil all over the cover of the engine and caused PO300 to comeup again. i have really bad idle which is at 1k RPM and when i have AC on it stalls when coming to a stop.
so what should i do? buy a new oil cover myself?
i have SSQV BOV, CAI
Old Sep 2, 2009 | 08:51 PM
chaotichoax's Avatar
take it to AMS since you are in chicago
Old Sep 2, 2009 | 08:58 PM
jahnplay's Avatar
its a 3 hour drive
Old Sep 2, 2009 | 09:01 PM
sounds like it might be worth it
Old Sep 3, 2009 | 02:15 AM
mini_evo's Avatar
If it's a 3 hour drive, you don't live in Chi-town or the burbs.
Old Sep 3, 2009 | 03:11 AM
ChrisBond1's Avatar
i can check for you for a beer. :]
my dad has a shop in evanston. but judging by the three hours you say, you probably live in Indiana or Wisconsin..
where did you buy the car from?
Old Sep 3, 2009 | 03:56 AM
Tallen's Avatar
Silver Sponsor
Go back to Mitsu and ask them politely for your oil cap back (that or they forgot to put in one of the valve cover spark plug well gaskets), the idle is being cause likely by a large vacuum leak from said area. Also let them know you'll need a free oil change because of the oil you lost. Then never go back to a dealer, ever.
__________________
-Matt
http://www.SpoolinUp.com
Affordable COP Kits - Back in Stock!
"Performance without the Price Tag"
Old Sep 3, 2009 | 04:56 AM
JakeTheVIII's Avatar
Take it back to them and say it's not fixed..............
Old Sep 3, 2009 | 05:47 AM
sloAZevo's Avatar
so the replaced the valve cover gaskets? Or the oil cap?
I'm sorry, its early and I'm kinda confused. If the spark plugs are covered in oil again that would be a good indication they forgot something. Make sure the spark plugs are tight too while you're in there... If its just the top of the engine that's covered in oil, do you notice the engine smoking from the oil cap when its idling? I had an oil cap fail on another car and you could see it smoke from the oil cap.
Old Sep 3, 2009 | 05:48 AM
gsrboi80's Avatar
1. Get rid of that SSQV it's likely whats causing your drivability issues
2. Have the dealer replace your oil cap
3. Search P0300 this code has hindered Evos since their existence in the US. There are many things that can cause it. Ignition Issues, Drivetrain Harmonics, Idle timing if the car was previously tuned. There are many fixes as well. If all else fails you can simply disable the code in the ECU
You need to pin point when the car throws the code whether it be during cruise or idling.
Old Sep 3, 2009 | 04:29 PM
jahnplay's Avatar
took it to a performance shop and they said its compression problem
Old Sep 3, 2009 | 05:02 PM
TommiM's Avatar
dont do anything to it. take it back to the dealer as it is and have them fix it right. did you pay or was it warranty? if you paid then definately take it back. You paid to have it fixed and it wasnt.
Old Sep 3, 2009 | 05:14 PM
jahnplay's Avatar
i bought the car used with 3k Miles/3 Month warrenty, i got it fixed the spark plugs, wires, and some other stuff i paid $150 deductible, im going to call the service tomorow and see if they are going to rebuild the engine under warrenty if not then im going ask for my money back
Old Sep 3, 2009 | 05:32 PM
TommiM's Avatar
use that warranty then. get your leaks fixed. put a stock dv on there and have them check your driveability issue. Once its out of warranty then you can go to AMS or some other good shop in your area. my .02
Old Sep 3, 2009 | 05:37 PM
jahnplay's Avatar
ya i will see what i can do when i talk to them tomorow, thanks for your help
4g64t_dohc
35
Sep 8, 2021 07:16 AM
ak47po
33
Mar 21, 2016 11:31 AM
Hitmachine101
Oct 24, 2013 09:58 PM
Levar
Oct 11, 2012 11:59 AM
EVOllie
Feb 23, 2011 01:01 PM
