trying to raise headlights is this possible?
after lowering my car my headlights are not very high up so i want to raise them is there any way to do this? thanks
I'm not sure about the Evo 8 , but with the evo IX you can raise them. Right behind the headlights there is a bolt you can turn to adjust the beam up or down. I think there is a more detailed description in the howto section,
if it is an ocho then yes. Okay you can try under the hood, there is a nut that you need to turn in the back of the headlight assembly. You can access it from under the hood. Odds are that it wont turn because the wheel you turn is metal and is connected to another wheel made out of plastic. THe way I did was to remove my front bumper and directly next to the HID ballasts is a place where you can insert a phillips and turn clockwise to lift. Make sure you HIDs are turned off as you adjust them. If you look under DIY threads you'll find how to adjust your headlights.
Good LUck
Good LUck
