Anyone on here use Kroil?
Old Sep 13, 2009 | 02:15 PM
  #31
Krzano's Avatar
Kroil is an awesome product. We use it on diesel engines in the research/testing lab.
Old Sep 13, 2009 | 05:24 PM
  #32
AznEvoIX's Avatar
The ultimate question is!
How much does it cost. =X
Old Sep 13, 2009 | 05:45 PM
  #33
mmmmbst's Avatar
Veteran: Air Force
"2 king size cans doe $12"
http://www.kanolabs.com/google/
Old Sep 13, 2009 | 06:11 PM
  #34
AznEvoIX's Avatar
Kooooooooooool. Better than WD-40 you say? I must try this.
Old Feb 16, 2010 | 10:50 AM
  #35
fugiwara's Avatar
PB blast is better than WD 40, is WD 40 the only thing you use/know?
Can kroil be picked up in any auto parts store?
Old Feb 16, 2010 | 02:13 PM
  #36
phenaly's Avatar
ATF & Acetone - 50/50 mix.
For me it has worked better then any type of off the shelf penetrating oils I've tried.
Old Feb 16, 2010 | 09:41 PM
  #37
JohnDoe1984's Avatar
Originally Posted by raginghadron
I'm sure most of you have seen this by now but here it is for posterity:
Code:
The April/May 2007 edition of Machinist's Workshop did a test of
penetrating oils where they measured the force required to loosen
rusty test devices. Buy the issue if you want to see how they did the
test. The results reported were interesting. The lower the number of
pounds the better. Mighty interesting results for simple acetone and
tranny fluid!
Penetrating oil        Average load    Price per fluid ounce
None            516 pounds
WD-40            238 pounds    $0.25
PB Blaster        214 pounds    $0.35
Liquid Wrench        127 pounds    $0.21
Kano Kroil        106 pounds    $0.75
ATF-Acetone mix        53 pounds    $0.10
The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio).
Considering the fact that acetone is a strong solvent and not paint-safe, Kroil does a pretty damn good job.
This was on page 2. Apparently atf-acetone kicks butt on rusted bolts but is a little hard on some surfaces.
Old May 10, 2010 | 06:40 PM
  #38
fugiwara's Avatar
Thumbs up
that is great deal, thanks!
Old May 10, 2010 | 08:22 PM
  #39
evo8426's Avatar
im looking to do the o2 housing coming up in august when i move so ill be looking for kroil
Old May 10, 2010 | 08:26 PM
  #40
SyZyGy1394's Avatar
Kroil beats the hell out of pb blaster.
ThatchMoney
22
Mar 16, 2017 09:22 AM
Evo_Goodness
Sep 18, 2016 10:52 AM
killerpenguin21
33
Jul 23, 2016 01:12 PM
ToddRhodes
Sep 13, 2012 06:14 PM
vtluu
Aug 10, 2004 12:13 PM
