how to disassamble a evo ix wing
Old Nov 16, 2009 | 07:58 PM
evoIXmyninja's Avatar
how do you remove the top 2 bolts...its hard to reach with the socket and it seems to be a 12mm
Old Nov 16, 2009 | 08:00 PM
removing evo 9 wing
how do you remove the top 2 bolts hard to reach with the socket and it seems to be a 12 mm? any suggestions
Old Nov 17, 2009 | 09:50 AM
EvoRob22's Avatar
Originally Posted by pwrofturbo
I loled!
Old Nov 18, 2009 | 07:13 AM
wtf_is_a_evo's Avatar
I have tried to remove the side parts and it started cracking and poping so i stoped should i get a heat gun on my evo 8 wing and then try and what did you all use to pry the side parts off?
and LOL at the hammer
Old Nov 18, 2009 | 03:58 PM
Dragracer187's Avatar
I just pulled hard, and it came off, first I was scared to break it. But keep pulling steadily and it will come off. They are not glued together, at least not on a ix. They are attached with some sort of velcro. Don't use a heatgun.
Old Nov 18, 2009 | 04:22 PM
digdat's Avatar
I've heard the velcro thing from a few different people now
The key seems to be to pull straight up, slowly and hard. Don't bend it or push it out to the side or anything and it will come up. Using a heat gun could heatup the glue that the velcro is used to adhere to the car itself, I wouln't use a heat gun. Just pull but gently.
EVOlutionary
Mar 19, 2011 08:36 PM
PCToolsWiki
Nov 1, 2010 02:16 PM
xmaciek82x
Aug 18, 2009 06:59 AM
CG5TougeMaster
Jan 26, 2006 11:58 AM
