Problem with wideband
Old Sep 20, 2009 | 05:31 PM
def1's Avatar
My wideband has worked perfectly for months but now it is starting to act up. When I first tturn on the car it will work and read the right afr but about 2 minutes later it will just turn all the way lean and not read the afr anymore. Im not sure what happened. Has anyone had this happen to them before? Can anyone help me try and figure out how to fix this. Did my wideband completely fail on me?
Old Sep 20, 2009 | 05:42 PM
GTijoejoe's Avatar
Be sure to check the connections, and the grounds etc....... When the sensors are done they usually read lean none stop in my experience.
Old Sep 20, 2009 | 08:27 PM
chaotichoax's Avatar
you could at least mention what brand of wideband
do you run...
meth?
race gas?
Old Sep 20, 2009 | 08:45 PM
def1's Avatar
I have AEM and run pump gas. The car will read normal settings and then just stop reading altogether. On the ride home just right now it was reading perfectly for 15 minutes and then just went back to going lean. When I unplug the connection in the wideband it reads 14.7 nonstop and once I plug it back in it will read fine again for a while then go straight to lean.
Old Sep 20, 2009 | 09:05 PM
watch this
http://www.youtube.com/watch?v=1mb4VmDd0ao
Old Sep 20, 2009 | 09:12 PM
garcias2k's Avatar
^ good info
Old Sep 20, 2009 | 09:15 PM
def1's Avatar
if my sensor went out already that is really weird. I've only put like 5000 miles on it.
Old Sep 21, 2009 | 03:13 AM
mini_evo's Avatar
5000 miles or 5 miles. Between race gas and it being electronic, stuff happens. There's been guys that have bought BNIB electronics and they were bad. Luck of the draw I guess.
Old Sep 21, 2009 | 01:11 PM
boostin_20lbs's Avatar
I don't know about the AEM one, but the innovative motosprts LC1 WB could be recalibrated, I had to do that a few times. It was called free air calibration
Old Sep 21, 2009 | 08:33 PM
aem uego is not capable of being recalibrated
kyoo
Jun 30, 2019 12:44 AM
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
yeayeaatou
Dec 25, 2014 08:11 PM
curisu
13
Feb 1, 2013 12:43 PM
Chabada15
Jul 22, 2008 08:42 AM
