About to go wingless!!
Old Sep 21, 2009 | 05:17 PM
evo unknown's Avatar
I've been thinking of going wingless, but first I need to find out how to remove the wing.
I have searched all over and cannot find a how to or anything. All i found out is there are some allen bolts to remove plus a glue compound to on the underside of the wing which can be removed with floss.
Can someone please point me in the right direction with a how to or anything please.
Also, what do you use to fill the holes? I have seen different ideas from rubber bumpers to vinyl stickers.
Thanks in advance!
Old Sep 21, 2009 | 05:34 PM
Blitz's Avatar
https://www.evolutionm.net/forums/ev...-teach-me.html
https://www.evolutionm.net/forums/ev...rear-wing.html
https://www.evolutionm.net/forums/ev...evo9-help.html
Sure you searched all over?
Old Sep 21, 2009 | 05:40 PM
srtboostin22's Avatar
theres 2 screw in black grommets.. unscrew them... 4 10mm bolts.. take fishing wire or dental floss and go under the wing o remove the adhesive. WAXXXXXXX all the glue off and your done.. i actually just got a friend at a vinl shop to cut some small white circles.. looks better than black plugs imo.. dont forget to screw back in the black grommets
Old Sep 21, 2009 | 05:42 PM
thank you all
well i thought i was sure, b.c i searched several pages of several different how to threads looking for anything related to the wing and even yahoo searched it.
Old Sep 21, 2009 | 05:43 PM
What about putting it back on? Is the adhessive tape required or are there any other options?
Old Sep 21, 2009 | 05:44 PM
CoachG's Avatar
Goo Gone works great for removing the residue after the wing is off. Smells nice too...mmm...oranges.
Old Sep 21, 2009 | 05:47 PM
Are you sure Goo Gone is safe on the paint?
Old Sep 21, 2009 | 05:51 PM
xISyKIx's Avatar
it is safe, i used it to take out my "lancer evolution" worked perfectly but be sure to read the instructions and use water everytime u put goo gone.
Old Sep 21, 2009 | 05:53 PM
The hundreds.'s Avatar
Yep goo gone is safe, you can also use wd 40. you need to get the double sided adhesive tape from 3m, its sold at autozone usually. Its red and the tape is grey. Oh yeah, watch out for the circles cause they might get rusted or crack.
Old Sep 21, 2009 | 06:39 PM
pwdrtoastman's Avatar
i used the goo gone and it workd like a champ. also i used body molding tape and it worked perfect.
Old Sep 21, 2009 | 07:59 PM
foxmr's Avatar
touch up the holes with paint before plugging or covering
Old Sep 21, 2009 | 09:15 PM
AznEvoIX's Avatar
I masked off part of the circle and primered it with rattlecan primer.
Preventive measures FTW.
Old Sep 22, 2009 | 04:32 AM
Smike's Avatar
See all links, search more. Closed.
1STI2EVOX
Feb 19, 2017 03:51 PM
EVOEMS
Jan 19, 2011 08:20 PM
Ant1
Nov 6, 2008 04:35 AM
coolnick
Nov 12, 2007 11:46 AM
hkfeet
Feb 13, 2005 04:20 PM
