Hazard light button doesn't light up
Old Oct 18, 2009 | 10:36 AM
Aar0nsite's Avatar
hey guys, for some reason my hazard light button is not lighting up!
i was taking off that long plastic part so i could get access to the clock because i wanted to take off this layer of see-through plastic that i put in, since i wanted my clock to light up blue. Instead it looked aqua... so i took it off i unplugged the two white connecters and took out the clock to bend the "Ile" pin and then i put everything back together...
however now my harzard light button doesn't light up now... i was also installing a radio but i gave up on the radio and took it to a shop to have it installed but they told me that the radio has nothing to do with the hazard light button bulb...
note: when you press the hazard light button the hazards work and all however the light doesn't light up when i turn the interior lights on...
can anyone help me plz
is there a fuse for that bulb inside of the button??
Old Oct 18, 2009 | 11:26 AM
barneyb's Avatar
I bought a malt at the Dairy Queen and sat it on the dash. It had a lid on it but as I drove away it fell over and slopped ice cream around. I cleaned it up but after that no hazard button light. One day I started spraying Windex on the button while turning the hazard lights on and off. It turned out the button was partially stuck. The bulb doesn't come on until the button is all the way out.
Old Oct 18, 2009 | 05:20 PM
Aar0nsite's Avatar
any help?
Old Oct 18, 2009 | 05:59 PM
drop24's Avatar
Did you try Barney's suggestion? Sounds like the button isn't coming out all the way.
Old Oct 18, 2009 | 07:45 PM
Aar0nsite's Avatar
i figured what the problem... but with that now i have a new problem...
well i took the hazard component out and i went ahead and took the bulb out... as i closely inspected the bulb... i could see that the filament inside of it were not making contact at all.... what does this mean? well the bulb is toasted.. so i need a new bulb...
does anyone know where i can find this bulb?
Old Oct 18, 2009 | 08:21 PM
MitsuJDM's Avatar
I once took off the long center dash trim before and when I re-installed everything the button didn't light up. I decided that I didn't give a ****
Old Oct 18, 2009 | 08:30 PM
Aar0nsite's Avatar
i bet ur light blew up too! if anyone knows were to get a replacement then it would be awsome
Old Oct 19, 2009 | 10:03 PM
Aar0nsite's Avatar
okay, i went to mitsu and got the replacement bulb... installed the bulb back in and still no light! is there a fuse for that light? does anyone know what is the fuse for the light?
Old Oct 28, 2009 | 11:22 AM
Aar0nsite's Avatar
any have any suggestions? i replaced the bulbs...
Old Oct 28, 2009 | 06:11 PM
han's Avatar
han
I just got the evo, didnt even know if that supposed to light on, my bulb might burnt out too
Old Oct 28, 2009 | 08:32 PM
MitsuOZ's Avatar
easy solution, if your bulb went out, now you have reason to build your motor. things like that get me through the day
Old Oct 29, 2009 | 09:16 AM
Evo8N00bie's Avatar
my 05 is got the same problem
Old Oct 30, 2009 | 02:12 PM
Aar0nsite's Avatar
last night i was driving the car and i notice something else too... the ACD button doesn't light up either... so for watever reason that hazard light button doesn't light up its also affecting the ACD button light... any suggestions, and building the motor would be fun! lol but wouldn't fix that light tho...
Old Oct 31, 2009 | 09:07 AM
halfnhalf83's Avatar
lol, yeah i didnt even know it was supposed to light up until last week when i rode in my friends. ive had my evo for almost a year!
it doesnt bother me too much...but im replacing it anyway. ive got plenty of those bulbs here at work.
Old Nov 1, 2009 | 06:29 AM
Aar0nsite's Avatar
check and see if the button the right of the steering wheel lights up (ACD if its an MR or i think its fog light in the GSR) well if that button doesn't light up then changing the bulb will not fix it, there is something else involve here... maybe a fuse, but which one??
