Evo Trailer Hitch
Old Oct 23, 2003 | 07:43 AM
Somni's Avatar
Evo Trailer Hitch
Going to be making the trek from Orlando FL to Denver CO and going to be towing a small trailer with da evo :P. Anyone have a trailer hitch on theirs out there or towed anything with the evo? Any odd behavior etc? Thanks!
Old Oct 23, 2003 | 08:02 AM
Dale_K's Avatar
I think the owners manual says no trailers.
Old Oct 23, 2003 | 09:06 AM
1QWKEVO's Avatar
um, ya..... you don't tow with AWD cars... thats a no no
Old Oct 23, 2003 | 09:10 AM
Quickshift's Avatar
Offsets the balance, not recommened.
Old Oct 23, 2003 | 09:21 AM
slt's Avatar
slt
Why Arn't trucks AWD? I have a jet boat that we pull with my g/f's GTI. I was going to pull it with the evo but couldn't find a hitch for it.
Old Oct 23, 2003 | 10:02 AM
RaX's Avatar
RaX
The STi can tow.
Old Oct 23, 2003 | 10:13 AM
gvr4v's Avatar
Thats why you cant find one. Its not recommended.
The only reason the STi can is due to the adjustable diff.
Old Oct 23, 2003 | 10:42 AM
mayhem's Avatar
huh what balance?
Realistically you should be able to tow maybe 200 lbs. Just make sure there isn't much tongue weight. It's the subframe I'd be worried about twisting. Just don't over do it and you should be OK.
And guys you need to explain what AWD and the non adjustable diff have to do with towing? I don't understand the logic. It's just extra weight
Old Oct 23, 2003 | 10:45 AM
1QWKEVO's Avatar
evo uses viscus clutchs to route power, adding a trailer will destroy them, it places too much load on the rear of the car and this in turn generates more force on the power routed to the rear, your not driving a truck, your driving a rally "inspired" car. When you see rally cars towing then you may tow too
Old Oct 23, 2003 | 10:47 AM
kdogg's Avatar
Originally posted by RaX
The STi can tow.
He mentioned g/f GTI .... , not STI.
Old Oct 23, 2003 | 10:49 AM
mayhem's Avatar
Wouldn't this only apply if traction was lost? Also isn't it always at a 50/50 distribution anyway?
And assuming a well balanced trailer is attached, meaing that only the weight of the hitch and arm is applying down force and all other forces would be lateral. Therefore equivalent to having 200 lbs in the trunk, back seat or front. Not making any difference at all. You guys with me on this?
Old Oct 23, 2003 | 10:53 AM
leaveit2bevo1's Avatar
In Timeout
um Mark (forgot his sn) one of the members of socalevo has a trailer hitch on the back of his evo. I asked him about it and he tows stuff not sure what he tows but it works.
Old Oct 23, 2003 | 11:01 AM
shiplemw's Avatar
The WRX STi is able to two... poster mentioned that he uses his girlfriends GTi. The STi can tow upto 2000 lbs. I would think you would be able to do this but I would not want to do it. As far as trucks, most are not all wheel drive, 4wd yes but there is a key factor, most trucks you can't take over ~50 mph with 4wd on or you'll render your front differential useless.
mike
Old Oct 23, 2003 | 11:16 AM
Secret Chimp's Avatar
Trucks are 4WD mostly...... The Evo is AWD.....BIG difference.
But I would imagine if you could keep the tongue loading at almost zero, you could pull a very light tralier as long as the trailer and what it is carrying does not exceed the maximum loading capacity of the car, including the passengers and whatever else you have packed into the car.
Autox guys set cars up to tow their race tires on a very compact trailer all the time. And most of these cars are not rated to tow either.
SC~
Old Oct 23, 2003 | 11:17 AM
bigd's Avatar
My Subaru Forester XT can tow just fine thanks. Also, people tow with the WRX.
