Im kind of Stuck with this CEL. Need Help
Old Nov 19, 2009 | 01:06 PM
jjm4life's Avatar
why couldn't they pull the code? even though its not a us spec car, isn't it still obd-2?
Old Nov 19, 2009 | 01:21 PM
Yakshii's Avatar
Originally Posted by Blkstreak
lol thats what i said....
thats what im going to do when i come by
Yakshii's Avatar
cause autozone is stupid. They needed to have it on their computer to look it up.
Old Nov 19, 2009 | 01:27 PM
tweakdsm's Avatar
try to buy one of the obd2 checker...it is cheap like 40-50 bucks, and see if it works, it is OBD2- how they cant look it up? so how you going to pass emmision test?
it is hard to tell without a scanner, i dont think it is o2 sensor.... car has not too many miles on it, maybe BOV? since it is VTA?
without a code is pointless.
Old Nov 19, 2009 | 01:59 PM
EvoRob22's Avatar
Originally Posted by Yakshii
if it WAS the sensor why would it go on and off? is there a reason behind it?
Lazy 02 sensor signal. The 02 sensor will start switching slower. A normal 02 sensor switches rapidly. When the sensor switches slower than parameters then the check engine light comes on. The sensor can work for a good amount of time and turn lazy. This is when your check engine light comes on. Then the sensor could turn back to switching fine. Making the engine light go out after some distance.
Old Nov 19, 2009 | 02:07 PM
Yakshii's Avatar
will this effect the car in any way?
Old Nov 19, 2009 | 02:11 PM
EvoRob22's Avatar
Car will go into OL Fault which just makes the air fuel mixture will be richer richer. You will see no noticeable affect. There would be no additional damage.
Old Nov 19, 2009 | 02:12 PM
Yakshii's Avatar
Well at least thats a relief. Thanks. i will check this out ASAP
Old Nov 19, 2009 | 02:14 PM
EvoRob22's Avatar
No problem. Good luck .
Old Nov 19, 2009 | 04:13 PM
xi0V3MR's Avatar
you can get into any ECM/PCM with any scanner by just going into Generic OBD. you dont have to actually go into the make and model of the car with this selection.
Old Nov 19, 2009 | 04:15 PM
xi0V3MR's Avatar
and Autozone people cant check it out cause they arent smart enough to actually use those tools. they just know how to hook it up and let the computer do the work and when the computer doesnt work, they tell you they cant read it. dumb.
Old Nov 23, 2009 | 08:38 PM
Yakshii's Avatar
turns out to be PO170 code. "Fuel Trim Malfunction (bank 1)"
did a search on here and came up with nothing. Turns out not many people with Evos have this problem. Dont know if its the O2 sensor or the BOV or what.
need help
Old Nov 23, 2009 | 09:20 PM
EvoRob22's Avatar
Google is a good tool
"The code P0170 refers to a problem with the computer control of the air fuel mixture. This is called Fuel Trim. Code P0170 means that the Fuel Trim has reached its limit for compensating for a RICH Fuel Mixture. There are several reasons for a rich fuel mixture problem.
I think that the best way to determine the cause of a rich fuel trim is to use a data streaming scan tool. Ihe first thing I look at is the grams/per second that the Mass Air Flow Sensor is reporting. I also look at the barometric pressure and compare it to the altitude of the location of where I currently am. If the pressure is off ( the baro pressure sensor is part of the Mass Air Flow Sensor ) then the whole fuel fuel reference map is way off either too rich or too lean depending on the error. Fuel pressure should also be checked to make sure that it is not too high or that the vacuum line to the fuel pressure regulator has not fallen off or become split. Take vacuum hose off and also try to start the engine. Fuel should not squirt out the vacuum hose. Good Luck!"
Old Nov 24, 2009 | 05:11 AM
gsrboi80's Avatar
Boost leak test the car man. A bad enough boost leak will cause a cell to trigger. Also check all vacuum lines.
Old Nov 24, 2009 | 05:44 AM
SmurfZilla's Avatar
I was getting a P0172 due to a boost leak. If you put those mods on and never had a tune that could be it as well.
