whats up with our diff
Old Nov 30, 2009 | 01:17 AM
vmrevo9's Avatar
Veteran: Air Force
beatrush also makes a set of rear diff bushings (more like spacers) they are about $65. i would like to know the part number to the Energy Suspension bushings to. i'm actually looking into buying soon. mine clunks more now with the ACT clutch i installed.
Old Nov 30, 2009 | 01:20 AM
Evokid03's Avatar
I actualy how those bushings in my car that i wil be selling soon, 45 shipped.. used for about 2k miles.. i ordered the ams mustache bar delete and it comes with its own.
so i have no need for the beatrush anymore
Old Dec 3, 2009 | 03:57 AM
lelek's Avatar
is diff louder with these bushing installed ? i mean normal driving
Old Dec 3, 2009 | 05:32 AM
Bobster22388's Avatar
Well since these bushings would stiffen everything up, it would only make sense that more of the noises would be transmitted through to the car.
Old Dec 3, 2009 | 03:02 PM
aschold's Avatar
Yes it is noticeably louder, but you get used to it.
Old Dec 3, 2009 | 03:48 PM
evo9onmymind's Avatar
i thought someone just said that installing the bushings will eliminate the noises. now ppl are saying it will be noisier? someone plz explain..
Old Dec 3, 2009 | 03:56 PM
rightaway's Avatar
i was thinking the same thing
Old Dec 3, 2009 | 04:50 PM
pfunk47's Avatar
The road noise and normal noise from the differential will be louder inside the car,get the mustache bar elimination kit and it will be even louder. The 'clunk' will be gone though as that is generated from the rear differential moving caused by soft bushings.
I have Buschurs Mustache Elimination kit and solid side differential mounts bolted it up without the small rubber grommet they suggested you reuse and you can hear all the noise the rear diff makes, it's very enjoyable as well as it improved the rear end response significantly.
After switching to the above mods and solid motor mounts I've realized that our 3 piece driveshaft has more play than it should and produces a small amount of 'clunk' when driving hard, you want that on a rally car pounding around dirt roads, not on tarmac.
Old Dec 3, 2009 | 05:29 PM
98autogstspyder's Avatar
Originally Posted by sickaudi777
is it bad for the engine if i use two step alot
Yea, remind me not to buy the car from this guy when he sells it.
I've heard of people going through their factory clutch in as little as 3,000 miles. If you keep this up, you'll be one of them.
Old Dec 3, 2009 | 07:58 PM
xRoguex's Avatar
clunk = bad noise.
road and drivetrain wine = acceptable noise.
Old Dec 3, 2009 | 08:59 PM
aschold's Avatar
Okay, to clarify, your rear-end "clunk" or "thump" will go away. You will pick up kind of a gear box type noise while driving. You'll know it when you hear it.
As far as the two-step and all the launches, if you like your transfer case, I'd chill out on all that. No offense but from the sounds of things, that car isn't going to make it very far without some kind of critical damage unless you change your driving behavior a little bit.
Old Dec 3, 2009 | 09:06 PM
Kracka's Avatar
See post # 2 for rear diff and driveshaft bushing info:
https://www.evolutionm.net/forums/ev...-100-time.html
I personally have the Energy bushings but for street cars prefer the Beatrush bushings due to less noise and far easier installation.
Old Dec 3, 2009 | 10:22 PM
kumazhao's Avatar
my car makes the same noise when i lift the clutch too quick
chmodlf
60
Oct 23, 2018 08:59 PM
Mauricio Evo IV
28
Feb 28, 2016 04:34 PM
dillon410021
Sep 27, 2014 07:55 PM
domzerozero1
Jun 3, 2012 09:16 AM
Werd
Jul 12, 2010 09:37 AM
