What's stock untuned boost limit?
Old Nov 29, 2009 | 02:24 PM
bsmart82's Avatar
20-22psi untuned, I would not go much higher than stock. I've hit boost/fuel cut at 22psi on a cold day untuned. Currently self tuned at 24psi which is about the limit on stock fuel system.
Old Nov 29, 2009 | 08:11 PM
aschold's Avatar
Originally Posted by oneofakindtrini
FOr daily use i'd say keep it anywhere from 15-17psi. And thats for DD. If you had to try to get it tuned at around 21-22psi. Play it safe man. Your not running Any alch. or meth And your on Pump gas.
Why? Stock boost spike is 19psi on a VIII, why would he want to go any lower than that?
Old Nov 30, 2009 | 01:08 PM
oneofakindtrini's Avatar
Yeah, but a lot of people who use the evo's daily have it around 15psi slightly more. And btw stock boost it 19psi, but tapers off to 17or18 up on top.
Old Nov 30, 2009 | 03:18 PM
EvoJoeIX's Avatar
i daily drive my evo and im tuned on over 30psi....
theres no need to turn the boost down. might as well not even get it tuned at 17 psi.... its not like these engines are made of glass
Old Nov 30, 2009 | 03:25 PM
EvoRob22's Avatar
Originally Posted by EvoJoeIX
not the smartest boost level to run on pump gas
+1 25 PSI is plenty for a street driven car
Old Nov 30, 2009 | 04:30 PM
aschold's Avatar
Yeah, I understand that, I own one and drive it everyday. And actually if you add an MBC, it doesn't taper like that.
Turning your boost down from stock is absurd. It comes from factory that way. Drive the car and enjoy it while you can, you never know when the car might be taken from you during an accident or theft. I've never understood this kind of mentality.
rahku
Aug 15, 2008 10:29 PM
_Chris_
Mid-Atlantic Region
62
Feb 22, 2008 10:38 AM
teamdomokun
Aug 15, 2003 05:54 AM
