What's stock untuned boost limit?
Old Nov 28, 2009 | 03:11 AM
F0RSAKEN's Avatar
My car gets a bit of overboost once in a while, hitting 22-23psi, and when it does it cuts hard. Normal? I'm getting tuned next Friday anyway lol.
Old Nov 28, 2009 | 09:04 AM
chaotichoax's Avatar
the tune should help...it's because of your un-tuned exhaust modifications for the most part
Old Nov 28, 2009 | 10:28 AM
evofabulous's Avatar
i could only do about 21 psi when my car wasnt tuned and it knocked like crazy untuned
Old Nov 28, 2009 | 11:03 AM
mressler12's Avatar
My car must be tuned then. When I purchased it from the dealer it was running about 26-28 psi without any cut out at all. I guess theres not really any way to find out for sure if it has been tuned though.
Old Nov 28, 2009 | 03:27 PM
if youre running 26-28 psi and your car is not bucking like a bull then the ecu has been messed with somehow
Old Nov 28, 2009 | 05:04 PM
SLYDOGRACING's Avatar
good exhaust,good tune with healthy turbo 30 cold and 28 hott
Old Nov 28, 2009 | 07:54 PM
mressler12's Avatar
Ya, i figured that something was done with the ecu for not having fuel cut or anything at that psi level. The problem is im not sure what. lol.
Old Nov 28, 2009 | 08:35 PM
EvoJoeIX's Avatar
not the smartest boost level to run on pump gas
Old Nov 28, 2009 | 08:53 PM
get some tools to monitor your car, mitsulogger or evoscan, cable and wideband. you will be happier knowing that your motor is running correctly
Old Nov 29, 2009 | 09:54 AM
BlackBat's Avatar
Yea if your running that high i would say it has been tuned.
Old Nov 29, 2009 | 09:55 AM
BlackBat's Avatar
I agree!
Old Nov 29, 2009 | 01:00 PM
oneofakindtrini's Avatar
FOr daily use i'd say keep it anywhere from 15-17psi. And thats for DD. If you had to try to get it tuned at around 21-22psi. Play it safe man. Your not running Any alch. or meth And your on Pump gas.
Old Nov 29, 2009 | 01:08 PM
EvoJoeIX's Avatar
get it tuned at about 24 psi and call it a day
Old Nov 29, 2009 | 01:10 PM
F0RSAKEN's Avatar
Yeah, I thought it was something like that, it only does it in 3rd or 4th, full WOT, anything less than full throttle, and it pulls fine. Tune T-minus 5 days.
Old Nov 29, 2009 | 02:12 PM
Just don't get on it too hard until you get it tuned. Your fuel and timing maps are most likely in need of help.
