ANYONE KNOW HOW TO disassemble tail lights??
Old Oct 26, 2003 | 10:59 PM
xkpbreaker's Avatar
im trying to take the plastic cover off the tail light but not sure how .. it seems to be sealed real tight by glue... tried putting it in the oven 20mins ..... doesnt work....
anyone know how to take it off?????
Old Oct 26, 2003 | 11:33 PM
VA_LANCER_RACER's Avatar
heat gun maybe, works with the headlights
Old Dec 28, 2009 | 07:21 AM
Bassicfun's Avatar
Not to revive a dead thread.. but searching for disassembling tail lights, this is the only thread of 2 that came up. May do the same, does a heat gun work well for this? Since this guy tried to bake his, and didn't come out with cookies or success.
Old Dec 28, 2009 | 07:36 AM
gsrboi80's Avatar
The tails are a lot harder to split apart then the headlights. Most dremmel them apart
Old Dec 28, 2009 | 07:54 AM
Bassicfun's Avatar
Found Oki's post. I'm set now. Thanks.
Old Dec 28, 2009 | 07:56 AM
chaotichoax's Avatar
https://www.evolutionm.net/forums/ev...ut-dremel.html
Old Dec 28, 2009 | 08:02 PM
murderedevo256's Avatar
heat gun and razor blade. I just did it and It was so easy honestly took ten minutes or so to seperate
Old Dec 28, 2009 | 10:22 PM
iEvoVII's Avatar
Thats how I did mine too.
If I could do it again, I would use a dremel next time.
Actually dremel further into the tail light (about 2mm away form the clear front lense. That way you wont need to paint a strip around the front lense to hide the dremel marks.
Old Jan 7, 2010 | 06:23 PM
workel2man911's Avatar
its a pain in the *** i used a heat gun and it still cracked and i went slow as hell
chlippo
Jun 28, 2016 10:59 AM
TheJugganawt
Jan 2, 2016 07:42 PM
speckit1994
Sep 15, 2014 01:23 PM
ONIMUSHA
Jul 2, 2004 01:24 PM
imapunkclaimer
West Region
Mar 28, 2004 09:56 PM
