Wipers stuck on!?
Old Dec 24, 2009 | 12:23 PM
b00stin evo8's Avatar
Wipers stuck on!?
Okay, so the last couple of days have been hell here in Chicago. Between the streets being sheets of ice and the temps numbing, I thought little more could go wrong.....
I go out to the lot last night to pull my car into the service garage (work at Toyota dealer) and when I got the car in the shop, turned the wiper stalk to off and well to put it simple it would not turn OFF!
Wondering if anyone has had this problem before, I would rather have dental work done with no gas then try to get Mitsu to warranty it. Anyone?
Old Dec 24, 2009 | 12:34 PM
tarmac4g63's Avatar
check the wiring under the dash by the dead pedal water can leak in there from a gromet and get in the wire harness im from chicago too this weather sucks
Old Dec 24, 2009 | 12:45 PM
Great I will check that out, anyone else?
gsrboi80's Avatar
Yup your problem lies here.
https://www.evolutionm.net/forums/in...lins-rain.html
Get out your trusty solder gun
Old Dec 24, 2009 | 10:02 PM
chaotichoax's Avatar
amen gsrboi
Old Dec 24, 2009 | 11:21 PM
tenaciousd199's Avatar
its a sign...only take it out in rain or snow
Old Dec 24, 2009 | 11:26 PM
tim85851's Avatar
:/ i was afraid it was going to be that leak on the harness...good luck and let us know how it goes...
Old Dec 26, 2009 | 12:03 AM
well I will have to check it out in the daylight. I am really hoping its not wiring, this sucks......
I did NOT need this right now, I wanted to get tuned, and get my turbo back exhaust
Old Dec 26, 2009 | 05:26 AM
gsrboi80's Avatar
99% man that is your issue. If you know what your doing it and do it yourself it'll cost you next to nothing. Just for some shrink tubing and a tube of silicone
If you have a shop do it your going to be paying between 2-4 hours labor.
Old Dec 26, 2009 | 03:24 PM
Well I removed the kick panel and looked at the wiring for a while. Nothing looks out of place but when I moved the one harness it had a spark somewhere and is making an interference noise??
I am a little worried since a short can lead anywhere and could cause a fire, so I am taking it to the dealer monday to see if they will do anything. The only two left within my area are Bill Jacobs Joliet and South Holland. Anyone know a good dealer to go to in Chicago Suburbs? I am stock....
Old Dec 26, 2009 | 06:14 PM
Routybouty's Avatar
Wow yea get that fixed quick. Leave your battery unplugged over night until you do. I don't think you need your car/house/neighbors house burning down. Your stock, nice! Take it in quick.
Old Dec 27, 2009 | 05:10 PM
gsrboi80's Avatar
Nothing will look out of place.
You need to take the connectors apart and you'll see all the corrosion on the pins. Its sparking cause there is power at those pins and their intermittently making connection to one other. Not Good
If you are going to take it to Mitsu for a warranty claim. Make sure you explain to them where the issue is. If not I can only imagine what kind of stupid things they'll tell you is wrong with the car.
IMO I'd just bring it to a reputable shop (Plenty in your area) and show them where the problem is and let them fix it by hard soldering all wires together and sealing the grommit up properly
Old Dec 28, 2009 | 09:13 PM
True, however I am trying to save some money right now for other investments so I think I am going to try to get it warrantied. I will point out exactly what is the problem so the techs hopefully cant screw it up!
I did look at it tonight and mine is so bad that I can't even get the connectors to come apart, TONS of the white corrosion powder everywhere. Its always small problems that make themselves a big deal!
Old Eagle
Dec 16, 2020 08:28 AM
AWD96
14
Jun 17, 2014 02:47 PM
youngcow
Feb 22, 2013 11:41 AM
stealthyevoviii
May 5, 2011 06:39 PM
sidtheretard
Feb 17, 2010 10:29 PM
