Evo 6 rear dif/ suspension
Old Jan 3, 2010 | 12:13 AM
raidokoiv's Avatar
Rear conversion you need Evo RS 5-9 rear diff,axles,front and rear diff brackets.USDM evo 8/9 models are same non AYC diff.
Other stuff, arms,hubs,subrame fit EVO 5/6 GSR/RS
Old Jan 3, 2010 | 11:58 AM
alexisrc's Avatar
I'm working on a similar project car but using a 2 doors mirage instead of the 4 door sedan. Rear sub frame are exactly the same as I compared it with my evo 8.
The only difference is with the rear upper arm that needs to be modified in order to fit.
Old Jan 3, 2010 | 12:08 PM
tiffsevo's Avatar
there is a guy on ebay that sells the stuff all the time at a good price i got a similar set up from him
Old Jan 5, 2010 | 06:51 AM
KX250Fmotoracer's Avatar
Originally Posted by Yogi_B
To answer your question about the front end, there was some changes made to the subframe on the evo5 which carried over to the 6 which was a change in height of the steering rack, so if you were to use an evo4 subframe then bolt in evo6 arms and knuckles (which go straight in) you could end up bump steer issues.
Oh was not aware of this. Ill try to find a complete Evo V or at least VI front suspension then.
I knew of the AYC, but didn't know that it used an external pump. I'll look into an Evo 8 or 9 rear then. Probably a lot easier to find in a junk yard anyway.
BTW Radiokiov that would be awesome if you could take some pics for me, would be a huge help!
Tiffsevo, do you know the ebay guy's name?
Old Jan 5, 2010 | 10:16 PM
Tachyonzero's Avatar
Just prefer to invest a lot of money, time and most important.... commitment
Old Jan 6, 2010 | 06:13 PM
Well i might have a problem that could put an end to the project. NY inspection is computerized, and an obd II evo ecu will show a VIN that wont match the registration.
Can the evo ecu be flashed to read a mirage VIN?
Old Jan 8, 2010 | 06:47 PM
nobody has any ideas about the ECU?
Old Jul 13, 2010 | 03:35 PM
UPDATE: Contacted NY DMV (a while ago) and they told me as long as the new engine is OBDII compliant it will pass inspection.
I also just picked up a Silver four door '98 Mirage at auction for $1040. Looks really clean, almost no rust, plus its got black interior which will make the conversion (a little) easier.
The project is on!
Old Jul 13, 2010 | 04:23 PM
where are you in new york?
Old Jul 13, 2010 | 06:47 PM
Near Poughkeepsie
Old Jul 13, 2010 | 11:07 PM
fatbao's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT
Old Jul 14, 2010 | 09:48 AM
That looks like a pretty clean conversion
However, I'm trying to build a VI TME, I'm not looking to buy one already done.
Old Jul 20, 2010 | 10:37 AM
Well guys, I'm VERY close to finalizing the import of an Evo VI GSR for parts, a RS quick ratio rack, FULL tommi makinen interior, and a tommi mak turbo.
Bye bye life savings...
Old Jul 20, 2010 | 10:40 AM
alexisrc's Avatar
Go on!
Old Jul 20, 2010 | 10:43 AM
alexisrc's Avatar
you can get the evo 6 ayc out of an evo x
