Cars not starting
Old Jan 11, 2010 | 11:57 AM
EvoVIII808's Avatar
did you try push starting the car? if you can push start it and it starts up then it is the starter, Or connections with the starter.
Did you check all your fuses? Make sure to double check ALL your Electrical connection. Positive and Negative. If starter not clicking its not getting power, or the relay is fried.
Do you have your Clutch switch disabled?? Car will do nothing if that switch is not released. (unless you disable it, so it can start like an automatic)
Also notice that your CEL stays on.. isnt it supposed to go of after a few seconds.
Old Jan 11, 2010 | 12:09 PM
EvolNinja's Avatar
I know you won't like this answer but the fast way to fix your problem is to move the battery back to its original location or get a mini battery kit. GL
Old Jan 11, 2010 | 02:00 PM
xxD3MONxx's Avatar
So yea the sound is most deff coming from the rear
... so the heat shield on i guess my gas tank is partially melted wtf.
and it looks like its been like that for awhile
Old Jan 11, 2010 | 02:05 PM
SPOOLEDTSiAWD's Avatar
sounded like the little clip (not the one that screws on) that runs to your starter came off, but you said its coming from the back of the car.
Is the wires that you have running to your battery damaged or scared up allowing it to ground out on the heat shield under the car?
Old Jan 11, 2010 | 02:18 PM
EvoVIII808's Avatar
weird..... has to be grounded to something.
Old Jan 11, 2010 | 02:42 PM
xxD3MONxx's Avatar
but all the electronics in the car still work?
Old Jan 12, 2010 | 09:20 AM
xxD3MONxx's Avatar
were is the starter solenoid at?
and if the starter is bad is installing a new one a bolt on kind of deal or should i got to a mechanic (really dont wanna waste the money)
Old Jan 12, 2010 | 09:36 AM
xxD3MONxx's Avatar
really need help on this i wanna get it done 2day if i can
Old Jan 12, 2010 | 09:40 AM
bigric09's Avatar
double post...
Old Jan 12, 2010 | 09:41 AM
bigric09's Avatar
starter solenoid ...
if you are under your car looking at your turbo out pipe... the little aluminum piece between that and the tranny is where the starter is at. I believe it is 2 bolts, one really long one and short one holding it in place. Last time i took mine off what when we did my clutch so i dont know about just taking it off by itself.
Old Jan 12, 2010 | 11:09 AM
xxD3MONxx's Avatar
Consider yourself responsible for fixing my car.
there was like a little black plug thing that was loose and i just plugged it in and bam it worked.
Old Jan 12, 2010 | 11:12 AM
EvoVIII808's Avatar
starter is easy. did mine without jacks. 2 size 14mm Bolts takes about 30min full install time.
Remove LICP, size 12 bolt for the power on the starter, remote switch just pulls off, and thats it. Slide it out, and place the other back in.
The place i bought my start from sent me one from a Lancer, so i just pulled the motor from it and placed it on my stock unit. Works Perfect.
Old Jan 12, 2010 | 11:13 AM
EvoVIII808's Avatar
Thats your starter switch. Figured it was that. good to see your back up.
