Seibon hood with rain
Old Jan 12, 2010 | 03:59 AM
manofhonor's Avatar
So I have the seibon carbon fiber hood, the oem, so it has the open vent. As of right now it's raining pretty heavy, so I went out and covered the vent with garbage bags. My questions are if I left the vent uncovered these next couple days while it rains, will I be ok? And driving around while it does rain, will I be alright? Thank you in advance.
Ps I'm posting this from my phone and it won't let me use the search function, so if this is a repeated question I apologize
Old Jan 12, 2010 | 04:15 AM
jester81783's Avatar
as long as you dont have water dumping directly on the air filter or battery you will be fine.
Old Jan 12, 2010 | 04:32 AM
4g634life's Avatar
only issue is pre rust on the headers and other metal components
Old Jan 12, 2010 | 04:48 AM
manofhonor's Avatar
I still got the heat shield on the headers so I think I'm ok. So it's ok to drive around then? I don't have to worry about coil packs burning up or anything of that nature?
Old Jan 12, 2010 | 04:54 AM
gsrboi80's Avatar
No issues man I have had a CF hood on my car for the past 2 years now. No worries it'll be ok
Old Jan 12, 2010 | 05:16 AM
NWEvoViii's Avatar
I have a Seibon cf hood and I swapped over the hood vents from the OEM hood over to the Seibon hood and in Washington, it rains a lot. I haven't had a problem with it and I've had my Seibon hood for over a year.
I don't think the vent opening on the hood is even over the coil packs so you should be fine.
Old Jan 12, 2010 | 05:34 AM
eve-slow's Avatar
Well, since it is OEM style and EVO's do drive in rain, you should be ok.
Old Jan 12, 2010 | 08:34 AM
RockmanX's Avatar
you will be ok
Old Jan 12, 2010 | 07:48 PM
GSX_TO_EVO's Avatar
My exact thought lol
Old Feb 9, 2010 | 11:52 AM
cash's Avatar
yea mine is all rust cause of rain
Old Feb 9, 2010 | 11:23 PM
rocinevoix's Avatar
you will be ok just some rust, and when starting her up you might get this smoke coming out, but its normal.
Screw that i took my cf hood for the winter due to the rain. Will put it on during the spring, and summer....
Old Feb 10, 2010 | 06:39 AM
SR_evo8's Avatar
Originally Posted by timmycat
i took the part that goes under the vent on the hood off and water got under the spark plug cover and the car had to dry out be for it would start
this is the reason why you switch the factory hood vents over! i've been running my c/f hood for 3 n a half yrs with no issues! Just switch everything over and you'll be fine!
Old Feb 10, 2010 | 02:59 PM
fast2go's Avatar
I had no problems when I had my Seibon hood on.
VETTE_50_TH
17
Mar 13, 2013 10:34 PM
warchild1212
Jul 5, 2012 09:07 AM
Evo8jpp
Dec 5, 2011 06:27 PM
sleepy_rps13
Aug 10, 2010 02:58 PM
Randog
Apr 15, 2009 09:35 PM
