Upgrade question
Old Jan 14, 2010 | 01:39 PM
Foolproof's Avatar
Upgrade question
I purchased my evo about a month ago and ready to start making some hp. Only problem I have is the stock fmic is bent a little but it is not leaking. I am wondering when I get my tbe, intake, o2 housing put on and have the boost turned up will it hold? I know there is no way to really tell but would you continue on and hope for the best of would your first step be to just get a fmic kit and start there. And if I do go the fmic route would I need a tune after or would I be ok for a few months?
Old Jan 14, 2010 | 01:59 PM
Bobster22388's Avatar
Get the intercooler pressure tested, that should tell you what you need to know.
Old Jan 14, 2010 | 02:04 PM
compscibOi's Avatar
Unless it has a leak in it, you should be fine. If you're worried about it, do a boost leak test before you tune.
Swapping in and out of a front mount isn't really going to require a re-tune unless you're going to be tuned to the edge or require a retune that will largely benefit from lowering your intake temps. (Anything over 400 IMO)
When you say make some HP, how much? What's your goals? What type of mods are you looking to do?
Old Jan 14, 2010 | 02:07 PM
Foolproof's Avatar
I am just looking to maybe 350whp atm. Not sure if I will go further in the future or not.
Old Jan 14, 2010 | 02:09 PM
compscibOi's Avatar
Unless it bothers you or you really do have a leak - replace it later on down in the mod path. I did mine early out of want, knowing later on I would benefit from it.
I went with the AMS FMIC. There are great ones from Extreme Turbo Systems, Buschur and others. Do lots of research and reading in the Dyno results threads / Engine threads. Lots of testing etc... Good luck.
Old Jan 14, 2010 | 02:50 PM
Foolproof's Avatar
Yeah I will go ETS when I do it. Guess I am going to make a leak tester tomorrow.
Old Jan 14, 2010 | 03:59 PM
ETS Michael's Avatar
Thanks Buddy!
Michael
Old Jan 15, 2010 | 09:37 AM
spoolinstyle's Avatar
I dented mine within the first week of owning my Evo. Luckily, someone on ebay had a special on their mishimoto IC's. Picked one up and I'm happy so far!
Old Jan 15, 2010 | 04:21 PM
Foolproof's Avatar
Sweet!! I pressure checked my IC and I am all good. About to get meh sum go fast stuff.
hatke147
Jun 23, 2013 05:44 PM
daechul2da
Oct 31, 2011 12:56 AM
XxLaNcErGTSxX
Automotosports - Illinois
16
Apr 26, 2010 05:58 AM
chrstn211
Mar 30, 2008 10:19 AM
Jeeperjunior
Feb 29, 2008 05:43 PM
