Is this rust normal?
Old Jan 26, 2010 | 09:37 AM
  #31
BlueEvo8JDM's Avatar
same as mine on my 8 as i sanded w heavy duty scotch brite then painted it black.. all perfect..
Old Jan 26, 2010 | 09:55 AM
  #32
kyoo's Avatar
Originally Posted by Steve_P
you need to treat the rust, then paint it. Undercoat is not a substitute for paint- it's main purpose is to protect floor pans and the underside of the car from rock chips and deaden sound. I wouldn't put undercoat on anything but the underside of the car body (floor pans, etc)- not on crossmembers. POR 15 is a durable paint that you can brush over rust that you might want to check out.
That's what the Eastwood rust converter is for.. then the undercoating
Old Jan 27, 2010 | 11:39 AM
  #33
mak1000's Avatar
Teroson Underbody automotive coat
Old Jan 27, 2010 | 02:38 PM
  #34
Steve_P's Avatar
you're missing the point. Rust converter is not paint. Undercoating is not paint. Convert. Paint. Undercoat (if you want)
Here is the description:
NEW FORMULA FOR 2009/2010! Eastwood's renowned Rust Converter is now available in a convenient aerosol package. This high tech formula halts residual rust in its track and converts it into a black protective polymeric coating, eliminating the need for sanding. The converted protective coating is now a suitable primer and is compatible with most top coats. Additionally, the protective coating will seal the surface and prevent future rust growth. To apply, simply remove loose rust with a wire brush and spray on Eastwood's Rust Converter, allow it to dry and top coat it with a quality coating.
See where it says "compatible with top coats" That means you should paint over it. And if any doubt, read the last sentence. Undercoating is not a sealer like paint.
Old Jan 27, 2010 | 02:45 PM
  #35
kyoo's Avatar
ohh you're saying I should paint over it after I treat it
Old Jan 27, 2010 | 02:58 PM
  #36
vipevo9's Avatar
its normal,i alsways clean it put and spray undercoat
kyoo
17
Oct 11, 2010 06:59 PM
kyoo
Apr 20, 2010 02:42 PM
kyoo
49
Apr 5, 2010 06:54 PM
kyoo
16
Jan 20, 2009 10:30 PM
kyoo
Apr 14, 2008 11:50 PM
