my hunt for 400
Old Jan 31, 2010 | 06:35 PM
evo8nfs's Avatar
my hunt for 400
So im getting tuned in a couple of weeks im pretty positive that i will reach my mark or come close to it... heres my mod list you guys think 400 to the wheels is capable..
walbro255
3"TBE
Ported o2
FP ported 10.5 hotside
stock ported exhuast mani
stock cams
hks cam gears
magnus sheet metal intake mani.
Stock evo 8 turbo
thoughts, opinions, suggestions?
Old Jan 31, 2010 | 06:39 PM
mifesto's Avatar
i'd say for safe/conservative 400whp on pump 93, you'd need FP green (if you arent using alk inj).... maybe you'd get close if your using 280 cams....
either way you wont go 400whp with that evo8 turbo and pump 93 alone
Old Jan 31, 2010 | 06:41 PM
ghammer2's Avatar
cams and a bbk-sauce... 400whp!
Old Jan 31, 2010 | 06:43 PM
4RETECH's Avatar
Stock turbo has gotta go. I've heard it's really maxing out at 380HP.
But I guess if you inject it you might get there, but too much stress on the stocker. That's why I went to the Kelfords and now getting a Buschur hybrid turbo.
Also, just a question, why cam gears on stock cams??
I am no Guru.......But, Based on your listed mods, I believe you're a long ways away from 400whp.......You'll need cams, fuel pump, injectors & an ECU flash......Peace =)
Old Jan 31, 2010 | 06:45 PM
sleeper04's Avatar
you should think about some cams.. alot of people with 8s are running the kelfords...but good luck on your quest
Old Jan 31, 2010 | 06:47 PM
RockmanX's Avatar
that mod list will get you no where near 400whp not even sniffing it you need alot more and as stated stock turbo should really be upgraded and you need cams since your a evo 8
Old Jan 31, 2010 | 06:55 PM
evo8nfs's Avatar
cams gears were on the car when i got it .. i have a set of bc 280 cams but im not sure i want to go with BC they were pretty much given to me in trade for work done... Id like to stay with the stock turbo due to turbos are way too expensive for my taste right now lol
Old Jan 31, 2010 | 07:02 PM
fugiwara's Avatar
walbro255
3"TBE
Ported o2
stock cams
hks cam gears
Stock evo 8 turbo
No cams? and you think you will be close to 400whp? in your dream... 350whp if you are lucky...
Old Jan 31, 2010 | 07:07 PM
EvolNinja's Avatar
Hey bro, I don't know how you can get 400 with what you go because I can't even with my mods. I suppose my clutch is going bad at the time of the dyno tune and perhaps a leak somewhere. But none the least, good luck though. I agree with the green, Kelford cams, and upgrade valve springs to support the Kelford cams, you should get to your goal.
Old Jan 31, 2010 | 07:22 PM
Turbo Meg's Avatar
Your closer to 300whp then 400whp. A set of cams, and a good tune, plus your current mods = aprox 330whp on a dynojet.
Old Jan 31, 2010 | 07:36 PM
4g63evoeight's Avatar
get rid of the magnus and stick with a ported stocker..
Old Jan 31, 2010 | 07:50 PM
denny424's Avatar
Its possible with E85. I just did it.
Old Jan 31, 2010 | 07:57 PM
evo8nfs's Avatar
I'd love to join the e-85 army unfortunantly it hasnt gotten to big in the pacific northwest..
Old Jan 31, 2010 | 08:10 PM
06redrocket's Avatar
nah even with e-85 your not going to hit it. Get head studs and cams and use e-85 and youll be over 400hp. Theres no way your hitting 400 with out cams like stated above. Sorry its just not going to happen.
