quick ecu question
Old Feb 15, 2010 | 05:06 PM
SeeCoryRun's Avatar
Originally Posted by gsrboi80
You'll need to flash your immobilizer code into his ECU one in your car. You'll need a tactrix cable, and EcuFlash on a laptop.
+1... and by the time you go to that much effort, you may as well just reflash his map into your ecu instead of a physical ecu swap. on the same note its still best to tune your car to the new setup. even though theyre the same parts, every car reacts diff to bolt-ons.
Old Feb 15, 2010 | 06:08 PM
EvoJoeIX's Avatar
thats why i said it would be easier to just do the map swap.
+1 on getting your car tuned, no two cars are the same
Old Feb 16, 2010 | 10:30 AM
Biggiesacks's Avatar
Originally Posted by EvoJoeIX
whoever told you that is wrong
Not really, you do have to reprogram the immob. code
Old Feb 16, 2010 | 01:04 PM
EvoJoeIX's Avatar
^ i read his post wrong. i know the immobilizer code has to be programmed. i said in my post earlier
