Lancer doors and Evo doors interchangable
Old Feb 18, 2010 | 12:56 PM
shuttlegoose's Avatar
I need a new front passenger side door on my Evo. I have been looking around for some but coming up with no results. I saw a few lancers and noticed the front doors are as close as you can come to being a perfect fit. Anybody know If it will fit?
Old Feb 18, 2010 | 01:00 PM
chaotichoax's Avatar
front doors I'm pretty sure are exact rear doors are completely different
Old Feb 18, 2010 | 01:13 PM
So your almost positive I can use a regular lancer front door and it will fit?????
Old Feb 18, 2010 | 01:36 PM
on mitsubishiparts.net they came up different prices but they use the same picture...that site doesn't list mitsu part numbers though
I'd pm russellm or call mitsubishiparts.net
Old Feb 18, 2010 | 02:30 PM
RussellM's Avatar
Plat Vendor
Lots of door part numbers. These are the numbers for each door - year splits and such. Hopefully this helps.
EVO FR RH DOOR MN150436 / 5700A040
EVO FR LH DOOR MN150435 / 5700A039
EVO RR RH DOOR MN150450 / 5730A024 / 5730A112 / 5730A114
EVO RR LH DOOR MN150449 / 5730A023 / 5730A111 / 5730A113
LANCER FR RH DOOR MR981682 / MN150436
LANCER FR LH DOOR MR981681 / MN150435
LANCER RR RH DOOR MR981690 / MR981688 / 5730A020 / 5730A18
LANCER RR LH DOOR MR981687 / MR981689 / 5730A019 / 5730A17
Old Feb 18, 2010 | 02:34 PM
digdat's Avatar
if it helps - i ordered side window deflectors for my 2005 evo8, which were actually for a 2003 Lancer OZ and they fit perfectly
Old Feb 18, 2010 | 02:40 PM
LANCER FR RH DOOR MN150436
LANCER FR LH DOOR MN150435
we have a winner and my thought was accurate woohoo
Old Feb 18, 2010 | 02:46 PM
RussellM's Avatar
Plat Vendor
Those numbers are for an early model VIII (03-04) and a Later Model Lancer (04+)
Im not sure what would even be different between them. Material? Cant say Im an expert on doors.
Old Feb 18, 2010 | 04:46 PM
OZR_Lancer's Avatar
the base lancer doors front pass and driver sides will fit 03-06 evo 8/9 they the same door basicly
Old Feb 18, 2010 | 04:49 PM
they will work that's all I know haha
Old Feb 18, 2010 | 08:47 PM
Appauldd's Avatar
I believe later models (03) have steel crash beams while newer models (04 & up) have aluminum.....I think.
All I know is my 03 doors are a lot heavier than new models.
Old Feb 19, 2010 | 01:29 AM
Aznknight47's Avatar
i think the rear is different, cuse of the wider fender. I'm not 100% sure.
Old Feb 19, 2010 | 07:57 AM
the rear is 100% different
however, the fronts are not (minus lighter crash beams)
that is a fact
Old Feb 19, 2010 | 08:04 AM
vipevo9's Avatar
yes a hear the front ones will fit, there are guys parting out evos on here with doors when i was looking for parts
Old Feb 19, 2010 | 08:33 AM
Appauldd's Avatar
I wonder if it is possible to swap out the steel crash beams with the aluminum ones????
