headlights and ac/heat fan inside cabin stays on for 5-10 sec after car is turned off
not sure if anyone has had this problem. When I turn the car off the headlights and ac/heater fan stays on for about 10 seconds, then everything goes off at the same time. Could it be a relay?
electrical problems
nah, this just started out of the blue. Freakin winters in NY always screw with ****. I used to have a similar problem with the fan in the engine staying on, but that was a bad relay and it was fixed. mayb I will try pulling relays, figured I'd ask 1st.
thanks
thanks
i have the same issues, only mine stays on as if the keys were still in the ignition to the "on" position, im in roughly the same climate, colorado front range and i had an apex-i auto timer that i have since removed the control unit on, still no luck.
cabin ac/fan issues
I pulled the relay from the small fuse panel under the hood and it stops when the key comes out. Im thinking it is a faulty relay but I have 2 get another 1st to check.
thanks
thanks
