DiaQueen correct?
Old Feb 26, 2010 | 06:36 PM
MitsuEvo1's Avatar
DiaQueen correct?
Hey guys, not too sure if this is the correct section to post, if not it can be moved.
Can someone verify if this is the correct fluid for the transf/diff and whatnot? I have a 06' IX SSL. I only ask because the jug looks different from the site, so I am not sure if I am good to go or did they send me the wrong one? I ordered it from Lancershop; Mitsubishi GL5 LSD Gear Oil Diaqueen : EVO 8/9 . Thanks!
Old Feb 26, 2010 | 07:51 PM
chaotichoax's Avatar
it's technically for the 6 speed tranny but it can be used in a 5 speed...most 5 speed owners that use it report smoother shifting
**IT IS NOT FOR THE TRANSFER CASE/REAR DIFF**
here is a link to a sticky in this section...searching around helps
https://www.evolutionm.net/forums/ev...uantities.html
Transfer Case
- Mitsubishi Limited Slip Differential Oil (LSD) or equivalent
- Diaqueen LSD Fluid - 3775610 (1 gal)
- capacity 0.63 qts
Rear Differential
- capacity 0.58 qts
Old Feb 26, 2010 | 07:52 PM
btw that price is a steal this stuff is usually 80-90 bucks
so if I were you I'd keep it and just order the lsd gear oil from another vendor that can get it right...russellm would be a good choice
Old Feb 26, 2010 | 09:39 PM
MitsuEvo1's Avatar
Wait, so I did received the wrong one then.. I ordered this from Lancershop; Mitsubishi GL5 LSD Gear Oil Diaqueen : EVO 8/9 .
Old Mar 1, 2010 | 12:41 PM
snowborder714's Avatar
There is some good info starting around post #6 in this thread about the two different gear oils.
https://www.evolutionm.net/forums/mi...22-fluids.html
And yes, you'll need different fluid for the transfer case and rear diff. It's shown in the link I posted as well as the link posted above in post #2.
Old Mar 1, 2010 | 02:35 PM
correct, you did not receive the right item
MitsuEvo1
12
Apr 6, 2017 06:39 PM
MitsuEvo1
For Sale - Wheels / Tires
20
Oct 16, 2016 09:53 AM
MitsuEvo1
For Sale - Cars For Sale
Jun 23, 2012 08:50 AM
MitsuEvo1
For Sale - Miscellaneous Automotive
May 12, 2010 08:41 PM
JebusMKIV
Apr 30, 2010 01:36 PM
