Mini Battery Question
Old Dec 25, 2010 | 06:22 PM
erald01's Avatar
i have the muse battery tray and i am not sue if it is adjustable, but braill batteries are a little shorter though i noticed that.
Old Dec 25, 2010 | 07:50 PM
ryukinevo's Avatar
Originally Posted by erald01
need some info on this mini batteries;
1) When you buy one do the batteries come with the terminals already or do they have to be purchased seperatly??
2) Now i see sooo many kinds of mini batteries and the whole 220 CCA worries me since it gets as low as 5 degreez here. And odessey pc680 seems way too much money for a small batter, whats the reviews on the other ones, such as braille and stinger??
I was worried about the 220 CCA in the midwest as well.
I ended getting a Optima for free because I had a full size one that went bad and Advanced Auto let me trade it for the Honda size yellow top-> lucky me....
It is taller than I would like, but for free or $130 it is a lot cheaper than a $270 Braille battery with the same 450 CCA.
If you got the $270 + $100 for battery tray laying around get the Carbon Fiber Braille otherwise get the Optima for $130 off Amazon or Advanced Autoparts will have a better local warranty if you have any problems.
Old Dec 25, 2010 | 08:05 PM
CoachG's Avatar
Could you throw a couple of engine bay pics up with the Yellow Top installed. I have been considering the Honda sized battery and pics of the install, orientation, etc. would help a lot.
Thanks & happy holidays!
Cheers,
Coach
Old Dec 25, 2010 | 08:07 PM
rocketmotor's Avatar
220 CCA seems to low for the cold for it to be effective.
Old Dec 25, 2010 | 08:48 PM
MR Real LA's Avatar
when putting on a smaller battery dont you face the problem of overcharging the battery and also overworking the alternator...i've heard so many stories of people not lasting very long with mini batteries...i'm running one, but took precautions, so i bought a voltage stabalizer from nrg and a grounding kit, and i can say that i have not had many problems with it...i say many problems cuz i do have an alarm and the cars lasts almost 2 weeks without being driven so i do have to give it the occassional jump start lol...
Old Dec 25, 2010 | 09:19 PM
ryukinevo's Avatar
Lightbulb
Because 220CCA is too low, I looked for other alternatives like the Optima and Braille that are 450CCA which is still lower than factory size, but a lot higher than 220CCA so you can run UICPs.
I do not have the Optima in my evo 8 yet, but I do have a pic of in another local guy's evo 8 that I bought his double pumper locally. I will post it soon.
Thank you!
Old Dec 26, 2010 | 03:12 AM
ixmrgg's Avatar
been running a Deka EXT20L battery for for bout half a year now, no problems. I live in SoCal, though - no sub-zero starts...
Also, just used a $10 battery hold down kit from pep boys to mount it; didn't want to blow $100+ on one of those fancy ones.
Old Dec 26, 2010 | 09:54 AM
erald01's Avatar
do the small batterie come with automotive terminals, or you have to buy them seperatly?
Old Dec 26, 2010 | 03:21 PM
ixmrgg's Avatar
The Deka I got didn't. You should be able to find some connectors for $10-15. Here's one example:
http://www.batterymart.com/p-odyssey-sae-terminals.html
Old Dec 28, 2010 | 11:14 AM
ryukinevo's Avatar
Smile
This looks like a cheap mini battery option also.
What is the CCA of this battery? I bought my Optima so I will not do the research on it, but here is the 3 quick links I found for everyone else.
http://www.iwsti.com/forums/vendor-g...unt-combo.html
https://www.evolutionm.net/forums/ev...ry-60-a-5.html
https://www.evolutionm.net/forums/ev...i-battery.html
Old Dec 28, 2010 | 11:33 AM
erald01's Avatar
so does the deka battery fit the usuall small trays that fit the odessey batteries
Old Dec 28, 2010 | 03:05 PM
DarwinX's Avatar
Did you guys know that the manufacturer of the Deka battery (East Penn) makes the Braille battery, right? Anybody who buys the over-priced Braille battery is just wasting your money.
For about $75 (and $10 for the SAE battery posts) you can get the Deka...together with about $5 for a universal battery hold down kit at Advance Auto, and you got yourself a great weight savings mod. My ETX20L weighs about 15 lbs and is on it's second Winter here in New England with no issues.
17.5 Ah @ 10hr rate
270 CCA
Old Dec 28, 2010 | 03:12 PM
erald01's Avatar
my problem is that i dont want to reroute the battery to the trunk, if that was the case i would have kept the original battery. Now does this battery fit a regular small battery tray? or is the battery bigger??
Old Dec 28, 2010 | 03:29 PM
djikonatx's Avatar
you dont have to reroute your original size bat to use it with the short route pipes.im using the original size battery with the buschur short route pipes.and whoever says that the mini bat s will give you the same performance as the original bats is full of it..ive worked with sound guys, ands just people that work on the mechanical side and they all told me for the performance too stick work the original size.all im waiting for is a custom mounting bracket for it.i dont get why you would wanna downgrade on something....instead of keeping it equal or better....
Old Dec 28, 2010 | 04:22 PM
still*boostn's Avatar
I got a BR battery tray for the 50 shipped.
