help! oil leak when high pressure.
Old Mar 9, 2010 | 03:20 PM
2003evolution's Avatar
any idea anyone? i find the oil allover bottom rear of engine. at frist it was oil return to oil pan, i replaced it and it dont leak anymore but i took her on the track down in nj and it seem to be still leak i couldnt find it anywhere. anyone can help me it would be great. thanks, im sure i ll figure it out. sooner or later.
Old Apr 3, 2013 | 02:19 PM
MR.Maxwell's Avatar
Similar problem. Assist if you can
My Evo 8 just started to leak oil. I haven't had a chance to look up under it yet, but will in a few days . ( garaged at moment due to leak ). The valve cover, and timing cover and the surrounding areas are oil free. However it seems to spray up onto my intake manifold from underneath, and onto my firewall when the motor is rev'd. I parked it for a week before going on vacation and there is a oil stain on the passenger side of the oil pan, and a puddle from the oil. I plan to look at it tonight and over the weekend, but any advice will be appreciated.
Old Apr 3, 2013 | 02:52 PM
slimjim1804's Avatar
Pictures would probably help
Old Apr 3, 2013 | 03:58 PM
chu's Avatar
chu
Clean up all of the oil, put in some engine oil dye, and start the motor. Use a UV light to see where the dye shows up.
Old Apr 17, 2013 | 11:34 AM
MR.Maxwell's Avatar
Thanks for the suggestions! The picture I took didn't do any justice and would have been a waste of time, as I couldn't disassemble much at all the last few weeks to get informative shots. Good news is that I found out where the leak was coming from, a small crack in the valve cover just above the new gasket, so I had it welded and taken care of at a shop.
Rs_mR_EVo
Apr 7, 2014 09:11 PM
rjfg
Jan 25, 2014 07:35 PM
fortyPSIrs
Feb 1, 2013 09:34 AM
bowlersp
Sep 8, 2010 08:42 AM
lfaboulos34
12
Oct 28, 2009 12:53 PM
