Anyone else had issues it's their oil drains?
Old Jan 25, 2014 | 02:04 PM
rjfg's Avatar
So for awhile there I had a mysterious oil leak that I could not find the source of. It was leaking on top of the starter and leaving oil on the bolts of the oil pan leading me to believe the oil pan was leaking.
After re sealing the pan and STILL having the leak I finally left the car running with the accelerator pedal down I discovered that the oil drain line was squirting oil.
I finally took it off and discovered a series of small holes traveling down the tube that were on the ridges in the area of the piping that you can bend.
I'm just wondering how many other people have had this issue??
Cheers
Colton
Old Jan 25, 2014 | 03:07 PM
Biggiesacks's Avatar
Are you talking about the oil return line from the turbo?
Old Jan 25, 2014 | 05:13 PM
rjfg's Avatar
Yeah from the turbo to the oil pan I call it an oil drain
Old Jan 25, 2014 | 06:20 PM
Havent had that problem myself. Easy enough fix though just replace the line. Make sure you get new gaskets for the line to turbo and line to oil pan. There is a correct way to install them too so do a quick search on the correct orientation.
Old Jan 25, 2014 | 06:32 PM
rjfg's Avatar
No I know I already fixed it it was just an interesting problem and I was wondering if anyone else had had the issue. I'm not even sure how it is possible
Old Jan 25, 2014 | 06:55 PM
was the tube actually leaking? Could it have been the Turbo to Tube gasket that was bad?
Old Jan 25, 2014 | 07:08 PM
rjfg's Avatar
No there were literally small holes the size of a pen tip in the tube
Old Jan 25, 2014 | 07:31 PM
Thats just crazy, no idea what could cause that. Maybe rats chewing on it or something?
Old Jan 25, 2014 | 07:35 PM
WickedWhiteDemon's Avatar
mine has a small hole in it to i tlk to one of the guys at AWD they have a steel braided line they going to be puting in for me on friday if it helps any
Kamukasha
Lancer Engine Tech
Jun 4, 2017 04:27 PM
Tiresomejunk
Dec 14, 2015 04:53 AM
DEREK199574
Sep 23, 2014 07:22 PM
Deano_Engineer_
May 24, 2013 11:10 PM
MISHI
Nov 23, 2011 09:20 PM
