Can't go pass 312 whp
Old Mar 13, 2010 | 01:27 PM
  #31
Kracka's Avatar
Originally Posted by GG_9_SE
Its definatly not the tune. Shane at DB is one of the best Tuners in Minnesota.
Shane is THE best tuner in Minnesota and one of the best nationwide in my opinion. You really need to do a boost leak test, compression test, leak-down test, verify the timing is properly set, and pop the valve cover off to ensure none of the rockers are knocked off.
Old Mar 13, 2010 | 01:32 PM
  #32
Saleentones's Avatar
100% agreed.
Old Mar 13, 2010 | 01:37 PM
  #33
Walt's Avatar
I would check your timing belt and make sure it didn't jump a tooth... I have a fp black also and am about 465 hp 387 tq on a unfinished tune so far.
Old Mar 13, 2010 | 04:36 PM
  #34
tigerkill2007's Avatar
Yeah I will b doing thAt tomorrow right now it is too dark and Shane is a get guy and a great tuner I know he really tried all he can But for those three hours nothing worked so we called it quits right there
Old Mar 13, 2010 | 04:38 PM
  #35
Just want say thanks for all ur replies and all seems to b the same so I will taking alook at the compression boost leaks and timing tomorrow
Old Mar 13, 2010 | 04:40 PM
  #36
mrdevo's Avatar
What did you dyno with the stock turbo? Did you gain anything from the black and how was the car running previously?
Old Mar 13, 2010 | 04:42 PM
  #37
TommiM's Avatar
Originally Posted by tigerkill2007
I saw ur post and yea I ain't saying it is the tune...how do u check the compression though
youll need a compression tester and some air to test the cylinders.
I read through your thread and sounded like you havent actually done a boost leak test. Do one and see how many leaks you got, t-bolt clamps will leak if not secured completely straight and tightened down enough.
Old Mar 13, 2010 | 05:01 PM
  #38
BoostWhore's Avatar
go to autozone or discount i think they loan the compression testers out...
What plugs are in the car what are they gapped to?
cam timing
boost leak test
compression test
leak down
is the car missing any, knock? Somethings way off.
Old Mar 13, 2010 | 06:23 PM
  #39
cam timing
boost leak test
compression test
leak down
I am running some ngk bpr8es gap at .025
I Am going to do all the testing tomorow and there isn't any knock
Old Mar 14, 2010 | 12:10 AM
  #40
Aznknight47's Avatar
should be the tuner's problem.
Old Mar 14, 2010 | 04:18 PM
  #41
GG_9_SE's Avatar
Not the tuners fault turst me. I would bet my life on it.
Old Mar 14, 2010 | 11:28 PM
  #42
Xolition's Avatar
It's the tuners fault for sending him on his way with 300 hp on a BLACK.
Old Mar 15, 2010 | 10:16 AM
  #43
JJsEvo8's Avatar
27 PSI is way too much boost for 93 octane.. Plus the Stock evo 9 BOV is only good for 23-25 PSI MAX. Your best bet is to take it into the shop and have them take a closer look. I have seen something like this before where the fuel pump wasn't installed correctly. If you dont put the black rubber seal onto the pump nozzle first, then insert the fuel pump into the fuel pump housing, you will leak fuel. GL
Old Mar 15, 2010 | 10:28 AM
  #44
hotrod2448's Avatar
So, the tuner should just go through and fix all his **** when he is just hired to create a map?
I could see it maybe if his shop installed all the parts but, if it's just someone going in to get a tune you can't expect them to go through the car and fix any/all the mechanical issues present. Otherwise it's the owners job to make sure things are right before going in for a tune.
Old Mar 15, 2010 | 01:05 PM
  #45
K1tt3n5's Avatar
Hes on a black...
