Can't go pass 312 whp
Well update...
I haven't done a compression test yet but i did do a boost leak and timing check...well as for the timing the timing is fine and i will be doing a timing belt change soon since i am in the 60k's...as for the boost leak test the throttle shaft seal is leaking like a (*&^$...when I hooked it up it took less then a minute for it to leak out of the shaft seals...like I didn't even have one...so i ordered some mil spec shaft seals...so I will fix that and see how it goes...I already did some logs...and put it on the vdr...and i will do some before and after the leak have been seal...other then that everything is looking good...but I will do the compression test sometime this week...haven't been feeling so good lately...so that is what is going on right now...
Well I did the compression test and all looks good...they were 170, 170, 175, 175...
Ted B
148
Jun 5, 2025 01:24 PM
edovio
26
Dec 18, 2007 09:20 AM
