my engine wiring harness caught on fire ,help!!
Old Mar 14, 2010 | 07:44 PM
barneyb's Avatar
It isn't likely that anyone is going to be able to make a correct guess over the internet as to what shorted first. You are going to have to search it out. So, check if the main cable is fried all the way to the starter.
Old May 24, 2010 | 09:44 AM
makspeed's Avatar
This is pretty bad. I've never seen the main ground wire get that hot? Its usually the live+ wire. You have to pull the whole harness n uncover all the loom. Also if you just installed the plug per coil, start with that. I've mixed up on wire on my coil pack and also fried my harness.
Old May 24, 2010 | 12:27 PM
SeeCoryRun's Avatar
since its already been bumped back to life...
what was the cause of the shorting issue?
Old May 25, 2010 | 11:21 PM
cl271's Avatar
I saw the wiring harness start to melt from the cam position sensor,so I replaced the engine wiring harness and the cam position sensor....btw I heard someone had the same issue as me too,but didn't melt as bad as mine. I had fix this problem for a month now and my car is still running fine.hope this will help you guy .
Old May 25, 2010 | 11:28 PM
pennies_hatchie's Avatar
I want to say the battery ground.
Old May 26, 2010 | 09:18 AM
20gmr's Avatar
this guy knows his stuff.
In order for this to happoen it had to be either a power wire shorting to ground or a ground wire that got power. Either way id replace that engine harness and not even mess with that one.
Old May 29, 2010 | 09:34 AM
goldenEvo's Avatar
It is possible that the starter shorted or drawing too much amps to fry a ground cable. First time
I seen this happen on an Evo.
Old May 29, 2010 | 10:44 AM
barneyb's Avatar
More likely a bad connection. Resistance equals heat.
Old May 29, 2010 | 08:51 PM
goldenEvo's Avatar
By looking at the pic. on the batt. ground cable, looks like too much amps went through it. A short to ground on the ground side would not cause it. GL on the repair.
Old Oct 7, 2011 | 10:11 AM
Drifting Away's Avatar
this just happened to my car how much is it normally to replace an engine harness.
Old Oct 7, 2011 | 10:24 AM
SmurfZilla's Avatar
I would imagine a couple hundred
Old Apr 17, 2012 | 05:47 PM
Any idea what caused this?
Old Apr 18, 2012 | 09:22 AM
vinnieg's Avatar
You probably had high resistance at a connection in the circuit and had a high amp draw leading to an over heat in a wire causing the wire to melt and catch fire...
In simple words that really sucks good luck!
Old Apr 18, 2012 | 09:25 AM
Anarchy99's Avatar
$800-1200
Old Aug 23, 2015 | 12:32 AM
k20toEVO's Avatar
this happened to me also.. except it only melted the ground wire by the cam sensor? Does anyone know were the o-ring ground routes to by that sensor?
evo.matt
May 20, 2017 09:01 PM
Evo_Goodness
Jan 24, 2017 06:54 AM
moyassine
Feb 21, 2016 10:54 AM
Mitsu.kid.02
Lancer Aftermarket Forced Induction Tech
Jan 3, 2011 06:26 PM
