is it safe to wash your engine?
Old Mar 17, 2010 | 01:29 PM
  #31
need_an_evo's Avatar
Originally Posted by mrobs15
Isn't simple green 100% non-toxic?
yea just checked my bottle
Old Mar 17, 2010 | 02:10 PM
  #32
spdngdragon's Avatar
not sure if it is the case here or not, but just because something is non-toxic in one state does not mean that it is non-toxic in another state. When you add anything to the equation (in this case heat) you can reach the tipping point where you have put enough energy into the system to start a reaction. The molecules in the chemical can both come apart and recombine into other molecules (which can be dangerous) and they can react with the molecules in the air to make other molecules (which again can be dangerous). College chemistry rears its head...
that said I wash my engine bay. I stay away from pressure washing because I don't want to force water into a million little places to sit and start rust. I also stay away from electrical stuff where possible to minimize the risk of short...my 2 cents is up.
Old Mar 17, 2010 | 03:47 PM
  #33
VIIIrs's Avatar
i can't believe this thread is still going LOL
Old Mar 17, 2010 | 04:00 PM
  #34
Mark14's Avatar
Originally Posted by BenJ
the key is to cover your air filter, coil packs/spark plugs, fuse box, battery, injectors, and main wiring harness by the intake manifold. Run your car first to get it hot then park it and spray it down with simple green, let soak for a few minutes, then wash off. Some people let the car sit for a few hours to completely dry and others immediately start it up and air dry it; i've seen both work.
Also, try to keep water out of your alternator and I always let it sit in the sun for a few hours to dry before starting up
Old Mar 17, 2010 | 04:05 PM
  #35
Ryan.Kauz's Avatar
I paint 28mm WWII models and uase simple green as a paint stripper. Also, it will melt plastic models (found that one out the hard way)
Yes I realize that automotive plastics are of a much higher quality than hobby plastics, however I dont want to.
So no, I wont put that in my engine bay. And the smell is aweful! Dont want that smell in the cabin on the ride home from the detail bay.
Old Mar 17, 2010 | 10:05 PM
  #36
waynea's Avatar
possibly we should google this one
if you care
cool or very slight warm engine
brush or blow off the dust and large chunks of dirt
cover the intake, coils, alternator and aftermarket electronics that may not be sealed
P21S Total Auto Wash or some related degreaser to remove grim
clean rags and brushes
rinse low pressure hose or steam, not a power washer
remove water from spark plug wells with a dry sponge
wax painted metal
if your want it sort of clean right now
blow off dirt and chunks with the air compressor, wear goggles
wipe engine with a rag sprayed with wd-40
let wd-40 dry before starting
http://www.properautocare.com/howdoiclandd.html
http://www.pelicanparts.com/bmw/tech...s_corner-7.htm
/wd-40, duck tape, baling wire and a fire striker, more than enough to take over the world
Old Mar 18, 2010 | 02:01 PM
  #37
EVO8emUp's Avatar
Every winter, I spray WD40 all over the engine and engine bay. Every spring, I spray Simple Green all over the engine and engine bay. Let it sit for about 1 min. Hose the engine and bay. I don't cover a thing.
I can fire the engine up when I'm finished with no misfiring, or any problems for that matter.
Old Mar 18, 2010 | 03:48 PM
  #38
_des_'s Avatar
Originally Posted by DBallz
I think what most people forget is when you wash your engine bay you can apply engine bright or whatever cleaning product you want to use but when your ready to Rinse the cleaning products away. Your engine must be running. I have washed all 10 cars I have owned including my wife's truck and never had a problem. Check your CEL and come back to us
I've pressure washed my engine bay on every single one of my cars for YEARS!, The key thing is to have the car running as you wash it down. Works without any problems
Old Mar 18, 2010 | 07:55 PM
  #39
EVO8emUp's Avatar
I do it with the engine cold so the Simple Green doesn't dry up on the hot/warm parts.
Plus I didn't want to hit the hot cast iron manifold with cold water. But, if you guys are doing it with no problems, kudos.
Old Mar 18, 2010 | 08:34 PM
  #40
EVOJR$'s Avatar
hose + 4G63 = bad ju ju
Old Mar 19, 2010 | 08:32 AM
  #41
cec12789's Avatar
IT will be fine i do mine every once and a while i just cover up the areas where wires are and simple green works wonders! And dont go spray happy just wet a litte bit spray on cleaner get a scurb brush and spray lightly off... Usually than i get a towel and dry up as much as i can than start my car and let it run till it is hot and than turn it off and leave it alone for awhile so all the mosture evaporates, than i spray on some protectant and let it bling
Old Mar 19, 2010 | 11:51 AM
  #42
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Originally Posted by JWA
As said above, it is fine to wash the engine with a few basic precautions.
However - don't use Simple Green. Simple Green is very corrosive to certain metals, in particular aluminum. Use an engine cleaner that is made for that use. Mothers has a new one that is great at both de-greasing and shining at the same time.
Haha where does this come from Is that a fact cause I use simple green to clean my rims cause it's not as harsh as wheel cleaner and wont strip the clear coat on the wheels or brake caliper. I have used Simple Green in my engine bays for over 10yrs and no problem with it any of my cars. There is a extra strenght version maybe you mean that?
Old Mar 23, 2010 | 08:00 AM
  #43
Steve_P's Avatar
I wash the engine/engine bay on all my vehicles a few times a year; I've been doing this for 20+ yrs and never had a problem- but I do use a bit of common sense. I just use dish soap and a hose, engine not running and cool. I cover the engine with an old towel and wash the bottom of the hood first, then do the engine and engine bay. When I'm done I blow everything off with compressed air, then take it for a drive. Use common sense- don't spray anything full blast, try to not put too much water on electrical devices, etc. While I will agree that this is somewhat asking for trouble it's nice to have a clean engine to work on; if you do it a few times a year it doesn't take too long.
Old Mar 23, 2010 | 08:17 AM
  #44
FastLearner's Avatar
Any detailer worth their salt knows you can clean engine bays if you are smart about it. On my EVO I wash the engine the same way I wash the car exterior. I have used diluted simple green without ANY problems, but I really love using S100. Obviously you dont want to force water under the coil cover, into the air filter, or any of the electronics. Nothing looks worse than a nice car on the exterior with a grease ball under the hood. Anyways just my $0.02
Old Mar 23, 2010 | 02:52 PM
  #45
ExplosEvo's Avatar
Originally Posted by kanyonkid
i PRESSURE WASH my engine bay all the time?? Why is everyone saying its a bad idea to wash your engine?
Same goes for me. I pressure wash about twice a year. Never ever had an issue.
