is it safe to wash your engine?
Old Dec 15, 2010 | 05:29 PM
  #61
THE8UH8's Avatar
Originally Posted by erald01
spraying down a turbo engine is a bad idea, casue of all the vacumm line, turbo itself, ic pipes. oil lines and wiring. If he has a CEL get the code and find out. I clean my engine just by wiping down with a rag.
+1...I use just soapy water on a damp rag and that works just fine
Old Dec 15, 2010 | 07:24 PM
  #62
45kevo's Avatar
water and electronic componenets never mix , hopefuly drying does the trick
Old Jan 26, 2011 | 11:18 PM
  #63
Bcity's Avatar
Just use brake clean ! period
Old Jan 26, 2011 | 11:30 PM
  #64
4G63kevin's Avatar
The CEL could be your knock sensor? A buddy had his car detailed and I guess they hosed down the engine bay. When he got it back, the CEL was on and idling funny and rough. I took my obdii reader and checked the code. It was the knock sensor. We switched it out for another one and no more cel. Idles fine. I concluded that when the 'detailers' cleaned the engine, water must have reached the knock sensor causing it to malfunction.
Old Jan 27, 2011 | 03:40 AM
  #65
awdordie's Avatar
Originally Posted by darkside4G63
i detail cars for a living. i have pressure washed literally 100's if not 1000's of motors with no ill effects. we degrease the motor and engine bay, steam it off, and then we dress the motor (similar to armor all i.e. white water based shining agent). most of the time we steam the motor while its hot but it really makes no difference. the only difference in these cars (mostly stock) and ours is some of the electronics we add such as boost controllers, EDFC's, various engine management components. many of these come with instructions that require them to be mounted where they will not get wet. i would, on my own car, heed their warnings because they are telling you that their products aren't water proof. other than that you should be fine. hope that helps. oh, and the only thing i would be cautious of getting wet while hot are tubular manifolds. i dont have much experience with them at work but they are made thinner that cast pieces (also most cast pieces are seamless) and their welds may not like the sudden temp change. you can still steam them though just make sure that they are cold if you do and dry them off before starting the car to help prevent the metal from getting water stained.
Im willing to bet u work at manheim auto auction, where I use to work. Spraying an engine should not cause issues as he stated I worked where he prob still does as I stated and when we did it we steamed the engines wwith the car running with no problems ever. They even detail and spray gtr engines there now. Notice the word steaming. Its a heated pressure washer. The water is over 100 degrees to prevent hot blocks from cracking manifolds etc etc.
Old Sep 7, 2014 | 02:37 AM
  #66
EvoTurboTurk's Avatar
Is pressure hose in the engine bay safe?
& is there other solutions that can be less risky, I don't mind if it takes longer ??
Old Sep 7, 2014 | 10:26 AM
  #67
TommiM's Avatar
compressed air, a rag, and some cleaner/degreaser. I dont spray down my engine bay, but when I want to clean up around tight spots like around the steering rack for example, I will spray some degreaser/ cleaner and then get some compressed air to blow it out of the crevices. Safe and effective.
Old Sep 8, 2014 | 02:19 AM
  #68
Would degreaser leave any marks or anything as such?
Old Sep 8, 2014 | 06:50 AM
  #69
TommiM's Avatar
Ive never had any issues with it leaving residue or ruining paint finishes. I use something like some diluted simple green which cleans out the engine bay nicely without the excessive shine a engine degreaser leaves. But if your into that then degreasers do make an engine bay shiny.
pistons4550
Jan 18, 2017 02:56 PM
ILuvJDM
Nov 20, 2013 04:03 PM
wingnut
Sep 28, 2004 04:41 PM
touchmyjagee
Jun 27, 2004 12:01 AM
