Wont rev over 5k.
Old Mar 20, 2010 | 12:44 AM
mlstrdc's Avatar
I have had such a problem twice before. The first time was due to a misfire (bad plug) and the second was due to over-boosting (due to the weather / temperature transition). Both times when I pulled the code it showed up as a misfire.
Good luck!
Old Mar 20, 2010 | 01:10 AM
Liquid0401's Avatar
thats really wierd. My friend Andy had this problem too when he first bought his car.. He put a AEM EMS and it went away some im guessing it has to do with the CEL for your stock ecu.
Old Mar 20, 2010 | 07:07 PM
Still_Spinnin's Avatar
I found whats controlling the boost on the car, Its got a forge boost controller. Just a manual, But i turned it down like 3 or 4 clicks. Right now im in NY with the car, I bought it up here. I just want to make sure its safe to drive home. It seems stable though, And it will rev past 5k if im just slowly accelerating, Maybe it was just boosting too high. Ill be able to find out when i get off the island im on, its packed right now so going WOT is out of the question. lol
MAF sensors plugged in, Although theres two connectors that come off the harness that arent clipped into anything. dunno why. Ill try and get a pic up as soon as i can.
Old Mar 20, 2010 | 07:09 PM
More then likely. I plan on getting ems soon, But ive gotta catch up again after buying this car before i do lol
Old Mar 21, 2010 | 07:45 PM
Still cutting up after turning the boost down. I was looking under the spark plug cover, One of my wires looks a little rough. Im going to swap it out with one of my girlfriends extras when i get back to FL and see if it makes a difference.
Today i had my first little issue, I lost 1st and 2nd gear lol, After a short search, it was the shift linkage to the left of the shifter. clip must have popped off. I twisted up a paper clip to keep it in place for now, Its good to go
Old Mar 22, 2010 | 10:36 AM
andrewzaragoza's Avatar
also replace your spark plugs and put in the right gap.
Old Mar 22, 2010 | 01:11 PM
92gsxbaltimore's Avatar
Sounds like Plugs and Wires...if it's not a boost leak
Old Mar 22, 2010 | 03:22 PM
xRoguex's Avatar
mine id the same thing.. it was boost related - not rpm related .. try not going WOT and see if it will climb over 5k
Old Mar 22, 2010 | 03:30 PM
Rome-Evo's Avatar
have u tried to get it tuned or does it have 2 step..??
Old Mar 22, 2010 | 06:36 PM
Its still got two step, Its at like 5500, And it will go past 5k if im like 20% throttle.
Old Mar 23, 2010 | 03:27 AM
MR. EVO MR's Avatar
Originally Posted by Still_Spinnin
This could be, Theyve got the stock intake on there where the metal mesh is exposed, no pipe. ghetto as hell. Im picking the car up for a reasonable price, its got stuff done that the guy doesnt even know it has from the previous owner...I just would like to figure it out as soon as i can, I dont want to take this 2k mile trip to FL back home with it in limp mode or fuel cut or anything. Trying to play it as safe as possible.
you might get stuck, why dont you rent a flatbed from ?
gl
Old Mar 25, 2010 | 12:10 AM
xRoguex's Avatar
coils are dead.
Old Mar 25, 2010 | 12:37 AM
boostless's Avatar
Why would you buy another persons nightmare?
Old Mar 25, 2010 | 06:39 AM
dmcghie's Avatar
my guess is the previous owner tried to run more boost and didnt get it tuned properly....probably getting fuel cut at 5k when going WOT....do you have a boost gauge hooked up?
Old Mar 25, 2010 | 07:52 AM
EvoFlash's Avatar
ems isn't needed on these car so many people making huge power 800whp on stock ecu.I bet it needs a tune up (spark plugs) and tune take it to 1320 engineering and talk to jon he owns a evo 9 there in tampa he will get you all set and tuned with tamer from 4WS. When are you due to get home from your trip?
