MR Shift knob question
Old Mar 27, 2010 | 12:34 PM
yahu's Avatar
^uhm, take the sticker off and line it up-->apply adhesive-->gtg!
Old Mar 27, 2010 | 12:56 PM
thedru13's Avatar
Yah dont' think i didn't think about that. That is how I damaged my first one.. The sticker separated.. So didn't want to risk it.
Old Mar 28, 2010 | 01:54 AM
yahu's Avatar
^lol - ok. I'd use a little heat, maybe. Of course, that could cause the resin to separate as well I suppose. I don't know, my sticker came up fine. Just use a good tool to get under both pieces and separate from the metal.
Old Mar 28, 2010 | 02:05 AM
todaysivxx's Avatar
its gonna look ugly with a different shift knob though. imo.
Old Mar 28, 2010 | 02:29 AM
yahu's Avatar
^I'm not sure I'm reading your post in the correct context. This is the shift knob I had in my car for a while - it is a gunmetal Blox 490:
It looks pretty good to me. I got a Blox 490LE in platinum gunmetal since then that looks good too.
Old Mar 28, 2010 | 08:24 AM
thedru13's Avatar
Thanks .. I am replacing my OEM knob with another OEM knob.. I will see if I can get under the sticker again I tried using a razor blade and a tooth scraper thing neither worked. I also may put a nut on the shift threading that way I can adjust and screw the knob down and just have it the wa I want. IDK bit much work just to have the knob facing the correct way.
Old Mar 29, 2010 | 09:25 AM
Steve_P's Avatar
https://www.evolutionm.net/forums/ev...-straight.html
Old Mar 30, 2010 | 03:10 PM
eric06ix's Avatar
If you damage the sticker, can you buy just that, or do you have to get the whole thing?
Old Mar 30, 2010 | 08:20 PM
06mr775's Avatar
Originally Posted by thedru13
Ok trying to replace my MR shift knob. I can't get the damn thing off. Anyone have any secrets? I can not get it to spin.. Am I missing something?
I got mine off by wraping a towel around it and putting channel locks around the towel...came right off by turning it counterclowise without any damage at all
Old Mar 30, 2010 | 08:23 PM
06mr775's Avatar
I got mine to line up by putting a small washer inside the shift knob...depending on how bad its off you might need to use a couple washers. The have to be small enough to fit into the hole without touching the threads
Old Mar 31, 2010 | 02:06 AM
todaysivxx's Avatar
i just dont like how it doesnt sit flush with lever fpr reverse. just cant seem to get over that it doesnt fit. it looks like a shifter on an old school bus to me. otherwise i would love to get that blox. those are nice as hell
Old Mar 31, 2010 | 11:53 AM
TWM Performance's Avatar
^ You could check out our M1 Abrams RL shift knob that will fit the Evo MR and sit lower to match the RL lever. It's a shift knob specially engineered for cars with a reverse lockout mechanism:
M1 Abrams RL shift Knob
Thanks,
Frank
Team TWM Performance
Old Mar 31, 2010 | 12:33 PM
kane.s2k's Avatar
The Abrams looks like it has a nice bit of weight. I'm just not a fan of metal shift knobs and extremely cold/hot days.
Old Mar 31, 2010 | 01:43 PM
To be 100% honest I drive with one all year around and I never find it unbearable. I'm not going to deny the fact that it gets a bit warm in the summer and somewhat chilly in the winter, but it nothing that the A/C/heat for 5 min can't fix
That being said, if you really don't want to go with a solid stainless steel shift knob, we will be releasing some leather wrapped versions sometime this summer...keep an eye out for those
Patrick
Old Mar 31, 2010 | 06:40 PM
thedru13's Avatar
Thanks Everyone... Good dialog. I am going to have to try a few different things. Nothing is working as of yet. I keep seeing the question asked but not sure if anyone knows or not. Can you replace the sticker? Anyone know where to buy another one?
