MR Shift knob question
Old Mar 26, 2010 | 10:42 AM
thedru13's Avatar
Ok trying to replace my MR shift knob. I can't get the damn thing off. Anyone have any secrets? I can not get it to spin.. Am I missing something?
Old Mar 26, 2010 | 12:25 PM
Steve_P's Avatar
no, it spins off, CCW. Might try a rubber glove or something like that for more grip. Or find someone with some popeye forearms
Old Mar 26, 2010 | 12:33 PM
churbo's Avatar
Yeah dude it spins off....lefty loosy righty tighty. haha. I'm sure you know that but you sould be turning towards the Driver side. If you have some rubber tipped Channel locks they would work or if you are replacing that knob because it's defective or whatever then use some regular channel locks.
Old Mar 26, 2010 | 12:43 PM
CJ2X's Avatar
https://www.evolutionm.net/forums/ev...emoval-mr.html
Old Mar 26, 2010 | 12:59 PM
eliminator 429's Avatar
get more grip and make sure your turning it the right way, i have made the mistake of turning stuff the wrong way before then its even harder to get it off.lol
Old Mar 26, 2010 | 01:17 PM
hxc chris's Avatar
hey man are you looking to sell your MR shift knob by anychace? My IX MR was just stripped and im trying to piece it back together, let me know.
Thanks!
Old Mar 26, 2010 | 01:20 PM
mitsumanny's Avatar
Some of the MR knobs are lock tited on that's why some people say just spin it. I personally had to destroy mine by removing the CF piece on top to get to the hex nut inside it. Once I loosened that nut it spun right off.
Old Mar 26, 2010 | 02:18 PM
sir-eth's Avatar
Mine was lock tighted on by the factory. I managed to get it off by using one of the rubber strap type vice tools. I think these are usually used by plumbers for pipes and such but it worked great on my car. Even with this tool I had to put a good amount of torque into it. Good luck.
Old Mar 26, 2010 | 03:53 PM
churbo's Avatar
I've seen these...they will work good. Check Lowes or Home Depot.
Old Mar 26, 2010 | 03:58 PM
yahu's Avatar
My 06 MR had a hex nut under the shift pattern sticker.
Old Mar 26, 2010 | 04:11 PM
GgreyEVOIX's Avatar
lol it comes off pretty easy.
most people can't get it off because they have no grip, +1 for using gloves if you can't get it off. Mine came off with ease just using my bare hands.
Old Mar 26, 2010 | 04:14 PM
yahu's Avatar
^are you reading posts? Some of the MR knobs will not come off easy. You either need to remove the hex nut or strip it.
Old Mar 26, 2010 | 05:09 PM
monkey_187's Avatar
That is correct, if yours doesnt have it just turn that b!tch till it breaks loose. They use loctite on most of the parts on the Evo.
Old Mar 26, 2010 | 06:20 PM
rickay726's Avatar
i find this hilarious mine spun right off!
Old Mar 26, 2010 | 07:03 PM
thedru13's Avatar
Well I used a strap wrench to remove it. Finally got it off. Can't believe how tight that thing was on there. I put the one on I bought. A used OEM 6sp knob. LOL it doesn't line up sticker is upside down.... UGH NOW WHAT
