Boost Problem
Old Mar 28, 2010 | 11:46 AM
OneWickedIX's Avatar
Boost Problem
i just got my first evo ix and it wont boost past 10lbs anyone have any ideas?
Old Mar 28, 2010 | 11:49 AM
MEVOLV3's Avatar
Mods? WGA disabled or leaking boost
Old Mar 28, 2010 | 11:58 AM
detroit pistins's Avatar
first, list ur mods and mileage on the vehicle, and describe at what rpm ur hitting ur max boost.
then trouble shoot in teh following order:
1) make sure all of your couplings are nice and tight (eliminate any boost leak)
2) check for any cracked vaccume hoses
if the issue is not resolved, then
3) do a boost leak test (http://www.turboboostleaktesters.com/servlet/Service)
here is a good thread on how boost leaks kill power.
https://www.evolutionm.net/forums/ev...test-them.html
gl!
Old Mar 28, 2010 | 12:02 PM
the only mod is a boost gauge and it has 87,000 miles
Old Mar 28, 2010 | 12:04 PM
i checked the couplings and the vaccum lines for cracks and leaks..
Old Mar 28, 2010 | 12:18 PM
are u the original owner? has the turbo ever been opened, or replaced, if so, then check for the following
1) vband connection between the compressor and the hotside, make sure its tight and not lose. if it is lose, then exhaust gases are leaking and not creating enough pressure on the turbine to spin it. u should notice some exhausr residues around that area if a leak is present.
2) check the wga (waste gate actuator) arm, and see if it has a good tension on the flapper. do this by removing the arm from the flapper (by removing the lil pin that holds it in place), if the arm is too long, thus, the wga flapper is slightly opened, so its not allowing pressure to be build inside the hotside. if it is somewhat open, then ur car should feel very laggy.
nevermind, just noticed that u just got ur evo.
Old Mar 28, 2010 | 12:20 PM
well i disconnected the vacuum to the wastegate and it boosted past 20...
Old Mar 28, 2010 | 12:22 PM
what rpm do u hit 20?
it might very well be the wga arm needs some adjustments.
Old Mar 28, 2010 | 12:29 PM
check out the vid clips in this post to understand how the preload on the arm works and adjust acordingly.
Originally Posted by Evoryder
Link on how to set preload...actually on FP's website.
ZERO PRELOAD:
http://store.forcedperformance.net/m...preloadvid.mpg
STANDARD PRELOAD
(WILL CAUSE OVERBOOST ON RED/BLACK W/ 25PSI GATE): http://store.forcedperformance.net/m...td-setting.mpg
HIGH SETTING
(THIS WILL GIVE YOU 40PSI+EASY WITHOUT EVEN TOUCHING THE MBC): http://store.forcedperformance.net/m...gh-setting.mpg
Also, this wastegate requires super strength or leverage...i used a hammer to help me get it on.
Old Mar 28, 2010 | 12:30 PM
JFuego777's Avatar
Make sure the pills are in the boost control solenoid lines...there should be one at the "T" on the vac line to the wga, and one at the boost control solenoid. without the pill at the "T" you will only get spring pressure boost, which would be about 10-12 psi.
i think it was around 3500 id have to go do it again to be totally sure..
Old Mar 28, 2010 | 12:55 PM
would i still need thoes pills in if i just ran a mbc?
Old Mar 28, 2010 | 01:50 PM
chaotichoax's Avatar
no you would not
Old Mar 28, 2010 | 01:52 PM
mbc routing options and info https://www.evolutionm.net/forums/ev...vo-rx-pro.html
newevoxguy
Feb 3, 2014 06:52 PM
jk_evo8
Jan 19, 2014 07:12 PM
ScoobySAM
Jul 22, 2012 08:41 AM
purevo96706
Jul 1, 2008 10:22 AM
Evo_Jay
13
Mar 16, 2006 11:55 AM
