Car wont shutoff, no turbo timer installed?
Old Mar 29, 2010 | 03:12 PM
tsidrift1's Avatar
Ok guys, i get in my car, drive to work, everythings fine. I go to shut the car off, it stumbles abit like a diesal would. Put puts for a second, so then I quickly turn the key completely to the off position. The car putters a bit and shuts off.
I go to lunch, get home turn the car off. It wont turn off. Its acting like i have a turbo time hooked up. I do not have any turbo timer of any kind installed. The car will run for an infinite amount of time I thought. Eventually it did shut down after about 2 min or so.
The only other thing is, the abs light turns on as soon as I turn the key to off and the car stays running.
Any ideas?
Old Mar 29, 2010 | 03:13 PM
ODUB's Avatar
Gremlins. That's the only logical explaination.
Old Mar 29, 2010 | 03:16 PM
tripperfx3's Avatar
I had this issue and its a wiring issue. On the drivers side left kick panel theres a bunch of wiring that, when it rains, water will drip down and corrode the wires. You basically have to clip out the connectors and hard wire everything in. Theres a how too here on EvoM, but I couldn't find it.
Old Mar 29, 2010 | 03:19 PM
tsidrift1's Avatar
really? this sucks. Are there any names associated with it that I could search?
Old Mar 29, 2010 | 03:33 PM
kdubb03's Avatar
i think this is the thread tripperfx3 was talking about: https://www.evolutionm.net/forums/in...s-how-fix.html
Old Mar 29, 2010 | 03:50 PM
tsidrift1's Avatar
Thats it! I just took the connector apart and one of the pins just busted out and is stuck into the connector!
Guess its off to get some solder, and heatshrink.
Old Mar 29, 2010 | 04:19 PM
*.jdmevo8.*'s Avatar
thats sucks bro. hope all works good for you.
Old Mar 29, 2010 | 05:30 PM
tsidrift1's Avatar
got the bigger plug directly connected. Work on the small one and clean everything up tomorrow. So far, so good though. Car started every time and shut off every time!
Old Mar 29, 2010 | 07:33 PM
xRoguex's Avatar
This comment gave me chills lol
Old Mar 29, 2010 | 10:41 PM
babieeddie's Avatar
interestingggg....
Old Mar 29, 2010 | 10:50 PM
ValdezeEvo's Avatar
dang thats crazy, glad you got it all figured out. Glad evom had all the useful info to help ya out!!
Old Mar 30, 2010 | 05:03 AM
tsidrift1's Avatar
Yea, it was pretty corroded down there. I recommend everybody checks those connectors.
Old Apr 1, 2010 | 09:28 PM
howell's Avatar
If that wasn't the prob I was going to recommend checking ur vac lines. I had a crx that had a tear in the main vacum and it wouldn't shut off either.
Corbin09
Aug 9, 2012 02:24 PM
DocCola
15
Aug 17, 2008 09:33 AM
jojipoji
Apr 19, 2008 06:10 AM
gbwaacha
Oct 13, 2003 11:17 AM
