help!dont want my engine blow
Old Apr 8, 2010 | 09:31 PM
subliminal's Avatar
Recently i changed the air filter from a big cone filter to a small cone air filter and wen i did the change my car made a little explosion sound so i pull over and i check it out everything seemed but my service light came on and it turned out that the car was over boosting so i put back the old air filter back but it still does the same thing i also saw the MAFsen and it looked a little dirty i wanted to clean it but for right now im a stay away from it. Is this anything that can b fixed?
Old Apr 8, 2010 | 09:38 PM
JonahEVO's Avatar
Maybe your pipes blew off.
Old Apr 8, 2010 | 09:41 PM
subliminal's Avatar
wat pipes? i checked the intake hoses everything still looks the same
Old Apr 8, 2010 | 09:42 PM
evo unknown's Avatar
You may have overboosted and popped a clamp or intercooler hose loose. Do you have a boost gauge to confirm you are reaching full boost? Do you "feel" any loss of power under WOT in boost range?
Old Apr 8, 2010 | 09:43 PM
ODUB's Avatar
Lord help them
Old Apr 8, 2010 | 09:44 PM
Originally Posted by subliminal
wat pipes?
Your intercooler pipes or intake. Check all the clamp/hose/coupler connections from the intake onto the turbo, the turbo's j-pipe to the lower intercooler pipe (LICP), the LICP to the intercooler's passenger side, the intercooler's driver side connection to the upper intercooler pipe (UICP) and all connections there on all the way to the throttle body.
Old Apr 8, 2010 | 09:47 PM
EvoDan2004's Avatar
Recently i changed the air filter from a big cone filter to small cone filter. When i did this change my car made a little explosion sound ''back fire'' so i pulled over and checked everything out. Everything seemed to be ok but my service engine light ''CEL'' came on. It turns out the car was over boosting so i put the old filter back on but it is still doing the same thing. I also saw the MAF was a little dirty. I wanted to clean it out but for right now i am going to stay away from it. Is this anything that can be fixed?
now that i understand what your saying i can try to help you.
1. what brand is the old and new filter????
2. is this car tuned?
you seem to be hitting fuel or boost cut. if you MAF is dirty clean it out with APPROVED MAF cleaner.
Old Apr 8, 2010 | 09:50 PM
Yes, take off the filter and check the MAF for gunk. The filter may have been over oiled. That could explain the CEL however, it does not explain the "explosion".
Are there any modifications done to the car?
Old Apr 8, 2010 | 09:51 PM
subliminal's Avatar
ive had the pipe on the throttle body come off on me once and wen it did it felt like a total loss of power and i did check the hoses but its good it runs fine its just wen i decide to accelerate it feels like all the is going to kick in but yet it doesnt and it struggles but if i drive it normal you can here the turbo spool up just fine
Old Apr 8, 2010 | 09:53 PM
subliminal's Avatar
its a k n n air filter and its not tuned no mods only the filter
Old Apr 8, 2010 | 09:54 PM
Sounds like a boost leak. When you are at wide open throttle (WOT), are you able to reach full boost?
EvoDan2004's Avatar
is this car tuned????????? we know your hitting boost. do you have a MBC? is a wg line blown off? details my friend. we need details.
full mods list and if its tuned or not
Old Apr 8, 2010 | 09:59 PM
subliminal's Avatar
the car is not tuned the only mods that r done to it is the air filter. and wen i had the big cone the car felt just fine no problems at all it was only wen i switched it to a smaller one that it started acting up so i put the old one back on to hopefully go back to normal but it didnt. the car at wide open throttle feels like it wants to turn off kinda like wen someone runs out of gas
Old Apr 8, 2010 | 10:02 PM
Again, I will ask you, do you have a boost gauge to monitor your level? Does it "feel" like you are not getting full power?
Do you have a warranty because honestly, we cannot really help you much more because of the lack of details. Maybe bring it to Mitsu. and have them diagnose the problem or a shop that deals with evos.
EvoDan2004's Avatar
my guess is it is not the filter then. if you put the other one back on and the issue is still present then you have other issues. i think your hitting boost cut. but i dont know without seeing the car.
IMO get the car tuned. but before you do that change your plugs, boost leak test, clean your MAF and air filter.
