Clutch issues...shaking in first
Old Apr 13, 2010 | 09:03 AM
zshonk23's Avatar
anybody?
Old May 10, 2010 | 01:59 PM
ithizz415's Avatar
My clutch shudders only in reverse. Im at 52K on mine, does anybody think thats a sign that it needs to be replaced? I plan on replacing it at 60k anyway, just wondering if i should do it sooner.
Old May 10, 2010 | 02:08 PM
spooilinevo's Avatar
i was told when i got my clutch not to downshift for 500 miles. Just to put it in nuetral and use the break
Old May 10, 2010 | 02:14 PM
rgar's Avatar
As far as the chatter/shuddering goes. I've been told by several clutch company's that what you would describe as a shudder is what they call chatter. They use other terms for clutch noises. So I believe he's using the correct terminology.
Sorry I can't help with the down shifting question. I would just call act, actually I think their site has a live support you might try too. If you find out post back here.
Old May 10, 2010 | 02:48 PM
Dan0805's Avatar
Just got the Exedy Twin, i hear you and understand your concern but unless its a perfect engagement from a roll in my case i know it will shake or stutter at least.
Old May 10, 2010 | 02:51 PM
fugiwara's Avatar
even the OEM clutch has this symptom
Old May 10, 2010 | 02:59 PM
mrevoix2006's Avatar
just got an act in mine too the same things happened
Old May 10, 2010 | 05:07 PM
Blowstock06's Avatar
Sound more like it need to be replaced other then being broken again but it's new so I'm pretty sure just needs to be broken in
Old May 10, 2010 | 07:49 PM
zshonk23's Avatar
yeah im 1500 miles into mine and it has smoothed out a lot. i started hearing a loud whine today so im pretty sure my transfer case is going so here comes another huge bill
Old May 11, 2010 | 04:35 AM
crazybaldhead's Avatar
You use your brakes to stop the car, never use your engine/ tranny.
And when you are slowing down, rev match.
Don't know what that is? Google it, your transmission will thank you.
Old May 11, 2010 | 04:37 AM
To the OP, it's normal, try to follow the break in procedure and see if that helps.
tbaird58
Nov 6, 2015 12:58 PM
mainframe23
Lancer Troubleshooting
Jan 2, 2007 08:28 AM
inariv5573
17
Jul 29, 2005 11:59 AM
Deceit
Apr 24, 2004 11:28 PM
ChillinEvoVIII
Jul 22, 2003 02:56 PM
