Car bogging Wot or acclerating
Old Apr 23, 2010 | 08:50 PM
4RETECH's Avatar
Originally Posted by Ian0611
It does feel like it's not quite producing the same amount of power as when I first got it. If it is knock and the timing then what would be the solution?
A proper tune, that way at WOT, the AFR will be correct.
Old Apr 23, 2010 | 08:51 PM
BoostinBird's Avatar
Originally Posted by Jeeperjunior
It could def be the tune. You could possibly be getting knock and your car could be pulling timing bc of it. Does it feel like its way down on power? If so thats bc your car is pulling timing.
I put the car on a lift and drove the car on the lift in first It seemed fine till fourth gear then it started bogging again as if there was a load on the engine or a strain. but on the ground it starts bogging right away when on throttle. I hear no knocks from the engine what so ever and rev it up and the BOV goes off its holding boost fine.
Old Apr 23, 2010 | 09:04 PM
Dude its probably the tune. If you had a tactrix cable you could log it and send it to me or someone else and they could look it over for you to help you out. But without one your basically going to have to take it to a shop or find someone locally who knows how to tune an evo to get her running smooth. I buy evos off auctions frequently and when an evo owner (for whatever reason) is forced to put their car in an auction, they feel the need to take aftermarket parts or maybe try and screw their bank lol. anyways. Post a log and your map on here and some1 will be around to help you out.
This one was hit in the quarter panel and the front but it didn't go all the way towards the radiator. the Front mount was a little bent i replaced it. I picked this one 8500 shipped with all fees and everything 05 with 55k good or bad?
https://www.iaai.com/Vehicles/Vehicl...#anchorDetails
Old Apr 23, 2010 | 09:17 PM
Ian0611's Avatar
That's what I figured but I just wanted to make sure. Sorry Boostinbird, didn't mean to hijack your thread.
Old Apr 23, 2010 | 09:46 PM
^ no prob bro lol We're both looking for the same or similar solution anyways!
Old Apr 23, 2010 | 10:51 PM
TurboTim06's Avatar
definetly sounds like a knock/tune issue...check out the tune and get some logs posted up
Old Apr 24, 2010 | 10:22 AM
Ill see if i can post up a video on here by monday! but I dont see why the engine could be knocking the car. When i start the car and rev it in neutral there is no knock in the motor.
Old Apr 24, 2010 | 10:26 AM
SavEVOIX's Avatar
Have you done a leakdown / boost leak test?
Old Apr 26, 2010 | 07:27 PM
Jeeperjunior's Avatar
Its not going to do it as bad when its on a lift bc the car is going to be under any load. Probably the reason it did it in 4th is bc it finally reached a high enough gear that it put the car under a little bit of load and caused it to do it. I don't think you'll be able to hear the knocking that your knock sensors are going to pick up. Its not going to be like you bent a rod or something. Anyways. Download evoscan, get a tactrix cable and post your results or email them. In the mean time stay out of boost or your going to be hearing more than just your bov.
Old Apr 26, 2010 | 07:31 PM
Yea thats a pretty good buy. Haha. I shoulda snagged that one up bc I have all the parts to fix it here at the shop.
Old Apr 27, 2010 | 01:10 AM
^ your right though the car only bogs when its under load! I changed the spark plugs today and drained the old gas and put octane booster still nothing. no boost leaks what so ever. and the engine is not throwing off any codes. Only when i floor it and past certain RPM the car starts bogging when under load. The exhaust just starts backfiring and popping! So I'm guessing the Car prob isn't tuned right or my catalytic converter might be bad? I still highly doubt the engine is knocking. the car wasn't hit too badly from the front when i bought it. the major collision was the quarterpanel it was bashed in.
Old Apr 27, 2010 | 01:16 AM
06mr775's Avatar
You need to find someone in your area with a tactrix cable and datalog the car, you will probably want to change your plugs before datalogging. You will also need a wideband.
Old Apr 27, 2010 | 07:35 AM
euntaeyi's Avatar
Sounds like plugs. Probably an untuned Evo running rich. If you bought it at 55k then theres a good chance the plugs weren't changed. They can be black from being old too. You should try the plugs first since its easy then go for a tune to see what's really going on.
Old Apr 27, 2010 | 08:10 AM
fcapistran's Avatar
I have the same problem. I change the plugs and nothing happen. I need to get a retune hopefully next week.
Old Apr 27, 2010 | 02:44 PM
boozeup&riot's Avatar
+1
If you're running rich, it could be because of a boost leak. Metered air is escaping, you'll be running far more rich than your motor suspects (if a boost leak is present of course). If you're lazy like I am and don't want to make a boost leak tester, PPI offers a very nice piece.
