Evo got knifed BUT it's being ressurrected!!
Old May 10, 2010 | 04:42 PM
TKEVO's Avatar
Veteran: Air Force
They also tried to put gauges in and...........well you saw the engine bay work so I shouldn't even need to say anything. They aren't hooked up either. (Sigh)
Old May 11, 2010 | 09:39 AM
TKEVO's Avatar
Veteran: Air Force
I think the turbo is shot
Old May 11, 2010 | 09:51 AM
Jin-X's Avatar
man sucks to hear about that. Keep us posted on the repair status.
Old May 11, 2010 | 10:06 AM
heel2toe's Avatar
Wow that evo have been absolutely raped...sucks to hear. Good luck getting everything worked out.
Old May 11, 2010 | 10:17 AM
TKEVO's Avatar
Veteran: Air Force
Yea so I started the evo today and it is still spitting when you give it gas. Its weird where it is coming from. Also when you rev it, it smokes. I think its coming right from the turbo housing in the ceter. That's where all the smoke is coming from. Smells like burning oil. I used a telescoping mirror and the oil return line is not leaking
Old May 11, 2010 | 10:25 AM
SavEVOIX's Avatar
The seals on that turbo are probably boo boo
Old May 11, 2010 | 10:31 AM
evo unknown's Avatar
This is another reason to take it to an EVO/DSM specialty shop..Find the right shop who work on these cars because they love to and they will take care of it!
Old May 11, 2010 | 10:36 AM
TKEVO's Avatar
Veteran: Air Force
Yep we are already on that schedule
Old May 11, 2010 | 05:57 PM
TKEVO's Avatar
Veteran: Air Force
What would happen to his engine from that oil getting down into the spark plugs and further
Old May 11, 2010 | 06:30 PM
heavens turbo's Avatar
nothing. if it is only that much, it will just burn off and maybe leave some residue. if the leak is fixed, it will be fine. all that burning oil you're smelling may be just excess from previous leaks. best bet is to parts wash the hell out of that thing and let it dry and idle it for a while. if you really feel like diagnosing a hidden oil leak, clean as much oil as you can, then add leak dye and idle or drive it for a bit. then check with uv light. good luck.
Old May 11, 2010 | 06:34 PM
TKEVO's Avatar
Veteran: Air Force
In park and giving it some throttle, it spits then smokes.
The turbo has a bit of shaft play. I was able to move the wheel by the bolt. Moving it slightly
Old May 12, 2010 | 06:17 AM
1badgsex's Avatar
by the looks of that o2 sensor thats probally one of the problems... just look where the wires go into the plug there all mangled ! i would replace that first !!
Old May 12, 2010 | 06:40 AM
Bobster22388's Avatar
Wow, someone took a perfectly good Evo and turned it into what is now the majority of DSM's that are left, beat to hell and everything rigged on the car. It's sad to see what they are all coming down to when they are put in the wrong hands.
Old May 12, 2010 | 04:29 PM
TKEVO's Avatar
Veteran: Air Force
O2 sensor is fine now. No issues
Old May 12, 2010 | 07:06 PM
Ivan B.'s Avatar
Engine should be fine. Was it only the turbo return line that was leaking? Did the engine ever run low on oil?
The turbo should be fine as long as it didn't starve of oil. Some shaft play is normal on all turbos.
