Changed Spark Plugs, Car died from Cold Start
Old May 14, 2010 | 09:42 AM
josel_atr's Avatar
i pulled them out yesterday, i noticed that the gap wasnt .5mm or .0200 inches (gap suggested by tuner). so when i came home, i gapped them with a gapping tool, cleaned to valve cover while i was at it.
that was that. then, the same thing happened this morning. i tried to start it, started for like half a sec, then died. 2nd try worked. after that, it ran fine.
do you guys think it might be the heat range of the plugs? im running the BPR8ES (one step colder to stock replacement). i will be picking these up today, and hopefully itll fix the cold start problem...
http://www.maperformance.com/ngk-cop...s-evo-dsm.html
Old May 15, 2010 | 09:03 AM
nothere's Avatar
the idle problem sounds unrelated to the plugs, it may just be a coincidence that you changed the plugs at the same time.
I'd do an evoscan reading to find out what is going on. any cel?
Old May 15, 2010 | 10:28 AM
josel_atr's Avatar
no cel.
Old Nov 6, 2011 | 01:53 PM
wally7714's Avatar
What is the correct torque specs for spark plugs ??
maperformance
Evo 'For Sale' Miscellaneous
582
Feb 25, 2018 04:22 PM
inshallah
Jul 5, 2016 07:52 AM
Insanity Evo
Aug 18, 2010 12:01 PM
sanderson
Aug 10, 2009 02:58 PM
kaonashi
Jul 12, 2008 01:32 PM
