Please help!!!
Old May 20, 2010 | 08:59 PM
xiong's Avatar
Please help!!!
Okay so to make things short and simple... my car just wont start anymore!! i took it to the shop at TOBZ PERFORMANCE TUNING and he was trying to diganos it and like he couldnt figure it out. so bascially whats its doing is its not starting and it wont let anything connect to the ecu for example when i plug in the obd2 reader it will say ERROR and when tobz try to connect the computure it wont connect as well!
LET ME KNOW IF ANYONE HAS RAN INTO THIS PROBLEM..PLEASE!!
_________________________________________
515 HP @ 32 PSI 469 TQ on E85
2.3 stroker w. gt35r and slight ported stock head!
Old May 20, 2010 | 09:37 PM
heavens turbo's Avatar
usually, if you can't read the computer from the obd 2 connector, it could mean a couple of things. the wiring to the computer could have an issue, (bad pin, wire, fuse, ground, etc.), or the computer itself could be bad. if everything mechanically checks out, then you gotta start with the wiring diagram and start checking voltages and things in the starting system. the signal goes from the key, to the ignition switch, to the fuseblock, to the comp., and out from there. i could be missing some steps, but i'm sure someone there will figure it out. good luck.
Old May 21, 2010 | 09:40 AM
xiong's Avatar
we already traced it and everything is looking normal..is there some sort of relay that can cause this??
Old May 21, 2010 | 10:03 AM
05evoGSR's Avatar
I am assuming it was running fine then one day it just didn't start? If so more than likely you have a electrical problem. Start with fuses and important wire connection points that would affect starting the car.
Old May 21, 2010 | 10:22 AM
ETS Michael's Avatar
Tobz is the man! I'm sure he will get you taken care of. Have you tried a different cable/laptop connection?
What's it do when you try to start it?
Old May 22, 2010 | 09:10 AM
xiong's Avatar
its just cranks but seems like getting no sparks! but yeah tobz is the man and he will figure it out just posting up to give some ideas so he can relook over what where can the cause be instead of spending hours and hours
Blizzard25
Sep 7, 2014 04:27 PM
ilikeppie
Oct 14, 2011 11:57 PM
TKEVO
Aug 16, 2011 05:55 PM
silentsniper605
Jan 19, 2011 03:56 PM
qubit
Evo X Dyno Results
Jul 7, 2010 07:22 AM
