Smallest size injector for e 85
is anyone running 1000cc injectors on e 85, ive heard 1200 is as small as you should go, keeping in mind winter, and other factors.
also is anyone running a single walbro for e 85, ive also heard you need 2.
imputs always appreciated, thanks-
It depends on what your hp goals are. A 1000cc pushing E85 should get you pretty close to 400hp. You will run out of pump on a Walbro 255 before you use all of the 1000cc injectors, though.
NOT TO THREAD JACK* but just a quick question. I'm on a single walbro and PTE 1000cc injectors, I would like to switch to e85 on my FP red. Should I move up to 1450's? Currently sitting at 390whp at 26psi (previous owner so I dont know the IDC)
Personally, I'd go with the new FIC 1100's that way it gives you room to grow. But the smallest that I think you can get away with are 850's.
http://www.fuelinjectorclinic.com/cg...ey=IS125-1100H
Yes, currently I have 1350's with the Red. 1450's would have been better.
