Smallest size injector for e 85
Old Jun 2, 2010 | 01:00 PM
  #31
italianevo88's Avatar
Originally Posted by andrewzaragoza
check buschurracing.com or you could also try blaqops.
thanks
Old Jun 2, 2010 | 01:29 PM
  #32
evodood's Avatar
Originally Posted by DeatschWerks
A Walbro 255 at 3 bar will put out about 4200cc/min. As the pressure goes up, it's volume goes down. At 4 bar it will only push about 3600cc/min. That's barely enough for a 800cc injector!
@ DeatschWerks-I don't doubt your math but it seems like your calculating this linearly and constantly. i.e. pump straight to injector and injector always open, which is not the case. You forgetting pressurized rail volume which acts as a reserve for the injector(s) and the pump can catch up in the milliseconds when all injectors are closed. The pump is on continously where the injectors are momentary, so the rail volume helps accumulate pressurized feul for injector supply.
Don't forget time is a factor in your equasions and milliseconds add up.
@OP- A single walbro properly set up will support up to 480whp on E85. I was doing it.
Old Jun 2, 2010 | 02:37 PM
  #33
RoadSpike's Avatar
Not to mention it appears the evo is a sequential firing system for fuel meaning its only one injector firing at any one time not all four like the old batch fire systems.
Old Jun 2, 2010 | 02:44 PM
  #34
BLKCarbonEVO's Avatar
Originally Posted by italianevo88
Where the hell do I get a double pumper
You could just order a intake 255 and an inline 255 on a boost activation switch. It will be cheaper and works the same.
Mikey
Old Jun 2, 2010 | 04:37 PM
  #35
evodood's Avatar
BlaqOps
Old Jun 2, 2010 | 10:27 PM
  #36
I just changed my fuel filter today, it was pretty bad, but as i looked at my fuel pump, I decided to try to get 450WHP out of the single for now, since i need 20 other things
Old Jun 3, 2010 | 09:46 AM
  #37
XxApollynxX's Avatar
Hey your some one local as well, I have FIC 1050CC injectors and a single 255 lph walbro on E85 stock evo 9 turbo and its all good.
Old Jun 3, 2010 | 12:30 PM
  #38
TTP Engineering's Avatar
Depends on the turbo size. 1000cc is fine for any stock turbo sized application.
Technically if 560cc suffices in any Evo 8-9 stock turbo application and E85 uses approx 30% more fuel, then 750cc-800cc should technically work.
Womb Raider
Nov 4, 2016 07:05 AM
slvrevo84
Jan 4, 2015 05:40 PM
krisgoodwin84
Lancer Aftermarket Forced Induction Tech
14
Feb 24, 2012 08:15 PM
mullen
Jul 9, 2010 11:20 AM
05EvoVIII
Apr 5, 2009 08:09 PM
