about jdm heads...
Old Jun 12, 2010 | 11:14 AM
evotuner1021's Avatar
about jdm heads...
I have a quick question about the jdm heads guys
I decide Ill go with the JDM MR 8 cause I like the flat housing.. but I cant find the ones with the OEM HID , just non-hid. is it because they r Evo 8?
http://www.cimotorsports.net/motor-s...hi-evo-mr.html
^^ that the link from the page Ima get them.... on the "NOTE: seccion its says that they dont include wiring or bulbs, they r probably non-hid right?
thanks for all your help I really appreciated since the store its closed I now I can rely on you guys
Old Jun 12, 2010 | 11:18 AM
ErikB's Avatar
All JDM heads are HID. You use your existing factory HIDs with them.
Old Jun 12, 2010 | 11:23 AM
oh its cause on other web sites it says non-HID or HID equipped.
check this one out
http://www.gruppe-s.com/Evo/evoext.htm
for the evo 8 its says "housing"
Old Jun 12, 2010 | 11:29 AM
Bobster22388's Avatar
Why not just get them from Driveline and support a vendor at the same time? They even have a better price, and you know you can trust them.
https://www.evolutionm.net/forums/ev...aillights.html
ErikB's Avatar
Thats because they will include all the HID stuff for more money.
Old Jun 12, 2010 | 11:37 AM
bougs's Avatar
Gruppe is a vendor. I'm sure Driveline and Gruppe have 'PM' specials.
Old Jun 12, 2010 | 11:47 AM
i went to the driveline website and it still says the same thing "no wiring, bulbs, or electronic equipment included" I think its just the housing and you need to buy the after market HID's or I'm wrong?
Old Jun 12, 2010 | 12:35 PM
I realize that also, I was just suggesting Driveline in reference to the OP.
Old Jun 12, 2010 | 12:48 PM
hey will they work with the leveling motor?
Old Jun 12, 2010 | 12:56 PM
Evoardo IX's Avatar
OP, you are asking a lot of questions in very bad order. Here I'll help you since I did the conversion on my RS.
1. Buy JDM housings (driveline, gruppe-s, your favorite seller, etc etc)
2. If you car has OEM HID's, swap components, plug and play.
2a. If it doesn't, buy OEM ballasts and bulbs, the housing comes with wiring. Then you need to find a plug from a HID equipped car, because your halogen plug will not work.
2b. Or you can buy an aftermarket HID kit, just make sure is comes with a D2S bulb, not any of that "rebased" hid bulbs.
3. Plug everything and enjoy blinding oncoming traffic
PS: the leveling motor will work if you have the switch and OEM wiring for it.
Ed
Old Jun 12, 2010 | 01:26 PM
but will the aftermarket ballast plug will it fit right the one coming from the evo?
and hey you say blinding because how the headlights are level right?
Old Jun 12, 2010 | 04:21 PM
TommiM's Avatar
any issues with the headlight beam angles considering the jdm are right hand drive, and US is left hand?
Old Jun 12, 2010 | 05:38 PM
Evoardo IX's Avatar
yes, there is issues, because the left headlight aims higher, only thing you can do to fix that is open the headlights and replace the projectors.
An aftermarket ballast will plug in whatever way the aftermarket kit was meant to be plugged, it won't plug directly to your car and neither will the OEM ballast if you don't have HID already. You would need to find the wiring from a donor HID evo.
Ed
Old Jun 12, 2010 | 08:14 PM
sparky's Avatar
Originally Posted by ErikB
All JDM heads are HID.....
Wow, I dunno if this is absolutely the case under all possible circumstances. Go ahead and make these broad generalizations however, as i don't think that anyone is likely to argue with your blanket statements.
Old Jun 12, 2010 | 08:17 PM
cuycita's Avatar
just get the jdm evo 8 mr headlight and re use ur hid kit
