100-120 miles on a full tank of gas!!! WTH??
Old Jun 16, 2010 | 10:55 PM
  #61
jonny2735's Avatar
not good check that tune
Old Jun 17, 2010 | 12:15 AM
  #62
j03yYunG's Avatar
i get like 17 mpg.. maybe i should get my car checked out. lol
Old Jun 17, 2010 | 12:49 PM
  #63
djikonatx's Avatar
Originally Posted by JFuego777
OP, don't listen to 90% of what ppl say here. Most of them are completely wrong, even though their intentions are good. You will save money in the long run by taking it to a reputable shop that can diagnose the issue for you. If you do decide to throw an O2 sensor in it, just replace the one in the O2 housing right below the turbo....the one in the cat will not affect your fuel mileage. The MAF sensor can also reduce your fuel mileage, but you would most likely notice other driveability issues. Personally, I would vote for a leak in your intake manifold between the throttle body and the head. This will cause a high idle and set the code you are getting. Since there is extra air entering the engine, extra fuel will be added to compensate, and reduce your mileage. But like I said, you will most likely save money in the long run having it diagnosed properly.
i do agree on getting it diagnosed properly but do you really think having the car tuned then putting the car back to stock w/out reflashing wont affect your mileage? the whole high idle problem can also be stuff like your tps maf .other than a leak..etc. im saying this because i had a high idle problem that turned out to be a tps.
Old Jun 17, 2010 | 12:51 PM
  #64
teribble's Avatar
Wow
  #65
05SlvrEvo's Avatar
Wow...i usually do about 220 ish in the winter and about 260 summer.
  #66
SavEVOIX's Avatar
Sorry didn't read the whole thing but... do a leakdown / boost leak test. DIY up a Home Depot tester and you'll find leaks in a sec.
Old Jun 17, 2010 | 03:07 PM
  #67
italianevo88's Avatar
Originally Posted by Roberti22
your an idiot buying a Evo for GAS mileage was where you went wrong! you should have had a reason like loving one of the most powerful 4 cylinder engines on the planet as a reason to buy the car not gas mileage...but anyway something is wrong you should be getting more then that there a alot of things that rob gas mileage tho...old oil, how much u use the AC, air filter being dirty as *****, and the biggest of them all is Boosting it will burn gas like nothing..more air needs more fuel didnt mean to be a d*ck in the start of this post either im just saying
lets not get too crazy guys, just because you own an evo doesnt mean you have to beat it into submission. if i was rich id have a daily driver and my some what race car on the side. But there are people that get way better milage so obviously this car has a boost leak or needs serious tlc
Old Jun 17, 2010 | 03:37 PM
  #68
k20toEVO's Avatar
I am not rich by any means, but when I buy a car, which tend to do ever year lol.. I change the plugs, ALL fluids and belts and for some odd reason the clutch . that way you know ur maintance is DONE. but im pretty hard on my car, tuned at 400ish and I boost it alot. I still get 230-250 miles on a tank.
Could be tire pressure and alignment ect..
Old Jun 17, 2010 | 03:52 PM
  #69
newbieEVO8's Avatar
I had this same mpg issue and it was due to my egr hoses had blown off. Some people have already mentioned that but only refered to them as hoses around the throttle body. Please check those as it will affect your idle also.
Old Jun 17, 2010 | 04:08 PM
  #70
Kasaper's Avatar
The car always ran with that bad mpg? Or are you a new owner? Either way the Best Advise seems to be to have a reputable dealer check it out. Goodluck!
Old Jun 17, 2010 | 04:30 PM
  #71
E MAN's Avatar
are your tires at 20psi and so is your boost gauge everytime you drive?
Old Jun 17, 2010 | 04:46 PM
  #72
hitman28's Avatar
he says he hits 10psi between shifts on a stock evo. still should be getting roughly 17-20 mpg even with the accessories on.
op i say take it to get checked in.
Old Jun 17, 2010 | 04:55 PM
  #73
Lowso's Avatar
i get 220-250 with some aggresive driving and only have exhaust and intake. But damn 100 something has definately be wrong or you just boost 24/7
Old Jun 17, 2010 | 07:09 PM
  #74
biggieevoIX's Avatar
i get about 270 highway/city
Old Jun 17, 2010 | 10:32 PM
  #75
E MAN's Avatar
i get about 230
